Old 04-09-2005, 02:25 PM
crazy_m_fo's Avatar
crazy_m_fo crazy_m_fo is offline
Send a message via MSN to crazy_m_fo
94 cavalier heat/ac power
ive got a 94 cavalier and basically my heater/ac suck, plain and simple. the blowing power is just weak. thinkin i was mr know how i replaced the blower motor expecting everything fixed, no such luck. now ive read many other threads and couldnt find any that said wat to do in this case. so any help would be much appreciated. up here in canada winter is far from fun when ur trying to drive in -30 weather with a heater that takes half an hour to warm ur car up even slightly. so wat else could be my problem? thanx in advance again guys
Old 04-09-2005, 02:46 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 94 cavalier heat/ac power
are you getting hot air, just no circulation, or neither?
Old 04-09-2005, 02:57 PM
crazy_m_fo's Avatar
yah, i get hot air, but it just doesnt blow worth a sh*t
Old 04-09-2005, 03:27 PM
richtazz's Avatar
does the blower work on all settings? you could have a bad blower resistor that won't let the motor spin at full speed. IF the car has ever sat without being driven, you could have a mouse nest in the ducting that is restricting flow.
Old 04-09-2005, 03:30 PM
crazy_m_fo's Avatar
the motors does work on all settings and u can hear it get more power as u turn it up, as for sitting, not since ive owned it, but it has been useless like this since ive owned it, how would u recommend i check for mouse nests or watnot? from the blower motor side or from the inside somewhere?
