Old 04-09-2005, 10:28 AM
kentoncivic kentoncivic is offline
Send a message via AIM to kentoncivic Send a message via MSN to kentoncivic Send a message via Yahoo to kentoncivic
d16z6 swap
ok if anyone can help this would be great. i swapped out my d15b7 for a d16z6, now it idiols really bad and it has 2 map sensors. the one came with the engine and the other stayed on the firewall. i have 2 different plugins. i don't know what plugin to use, or do i connect them to make one and for get about the sensor on the firewall? I need help.
Old 04-12-2005, 10:24 AM
Mistaphace Mistaphace is offline
Someone would help you if your post was a bit more descriptive. Maybe even some pics....thats if you want help from here. Other than that I would suggest a local mechanic. Also, run a search on engine swaps, it may include info on the wiring.
Old 04-12-2005, 05:14 PM
rbhale32 rbhale32 is offline
mine has a CEL problem...
I did my swap with the same engine... and dont know how to fix the darn CEL from telling me somethings wrong with my auto transmission... I dont have an auto Transmission. Anyway.. I dont think I have any unplugged wires in my firewall... but let me check and get back to you on that....
Old 04-12-2005, 05:33 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: d16z6 swap
Just use the one that attaches to the throttle body and forget about the one on the firewall.
Old 04-15-2005, 07:28 AM
superfly_32 superfly_32 is offline
Re: d16z6 swap
To make it quite reading the auto tranny you need to take a resistor out of your ECU. I swapped trannys and had to do this. I do not remember the location of the resistor. I will try and pull the ECU this weekend and let you know the location.
