Old 04-09-2005, 10:18 AM
bluezom bluezom is offline
Question cranks over no start 99 f-150 4.6 efi
i get spark but no trigger signal to injectors will run on starting fluid. any ideas. need help.need more info? thanks.
Old 04-09-2005, 10:59 AM
dreymeek dreymeek is offline
Does it have an emergency fuel shutoff switch? My Escort had one and acted exactly the same. It activates in an accident, but mine tripped just sitting there.
Old 04-09-2005, 01:16 PM
Re: cranks over no start 99 f-150
Fuel Cutoff Switch Ok Thanks Any More Ideas
Old 04-09-2005, 09:00 PM
peppermrj's Avatar
peppermrj peppermrj is offline
On a friends gm when the throttle is to the floor it signals the pcm to initiate a clear flood mode. His throttle wasn't to the floor but the throttle position sensor thought it was.
Good luck and let us know.
Old 04-11-2005, 02:51 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Re: cranks over no start 99 f-150
you need to check your fule pressure. Check that and report back.
Old 04-11-2005, 06:32 PM
ModMech's Avatar
ModMech ModMech is offline
Both the spark and the injectors are ECM controlled, so any sensor that would take out one, will also take out the other.
Do you hear the fuel pump running for a short time after you switch the ignition on? If not, you have a fuel problem. First check for power to the fuel pump, if you have it, replace the pump.
Old 04-11-2005, 06:48 PM
I have 40lb fuel pressure at the rail. when i crank the engine over the theft lite keeps flashing on the dash will that kill injectors?? I think its suppose to stop?? I just put in a rebuilt pcm.Are the keys coded into the pcm?? thanks for the help.
Old 04-11-2005, 07:57 PM
ModMech's Avatar
Yup, the PATS "key" programmed into the new EEC is different than the PATS "key" in the PATS module and your ignition key. someone screwed up big time.
PATS = Passive Anti Theft System.
Old 04-13-2005, 09:05 PM
Thanks for all the help guys over and out.
