Old 04-09-2005, 05:36 AM
murphymotorsport murphymotorsport is offline
ECU problem
I got my car back from my mechanic and it's slower then shit he said he couldnt advance my timing and said i need a new ecu and now my car can go like 70 in 2nd and is slower then shit off the line......can someone help me cuz i dont know where to find a new ecu or what would work on my car my car is the 88 crx hf
Old 04-09-2005, 07:00 AM
stang805's Avatar
stang805 stang805 is offline
Send a message via Yahoo to stang805
Re: ECU problem
look around on ebay or somthin, if you feel like doin the swap get the mpfi intake and a pm6 ecu
Old 04-09-2005, 11:29 AM
91civicDXdude's Avatar
Re: ECU problem
i think your car is "slower than shit" becuase its a 70hp HF.
Old 04-09-2005, 12:10 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Re: ECU problem
Mang the Hf is all about gas milage... 62 hp, long ass gears, and congrats on getting the lightest year too.
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 04-09-2005, 09:27 PM
Re: ECU problem
i found this ecu on ebay will it work?
numbers on mine - 37820 pm8 L020 661 100107
numbers on ebay one - 37820-PM8-A030 660-123174
Old 04-09-2005, 09:33 PM
Scott82 Scott82 is offline
Re: ECU problem
if your car is a manual then get a ecu for a manual, if its auto, the get an auto ecu. Not sure how to tell the difference in the numbers
Old 04-09-2005, 09:38 PM
Re: ECU problem
both ecu's are for manuels but i heard that all the numbers must be exactly matching?
Old 04-09-2005, 09:52 PM
Re: ECU problem
i havn't heard that but i guess it's possible but i doubt it
Old 04-10-2005, 12:24 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
yes, if they are both PM8 ecus then they will work
i'd suggest using an Si intake which is bigger and running an Si Ecu (PM6)
Old 04-10-2005, 12:57 AM
Would that work? my car is only an 8 valve and the SI is a 16 so i could change the intake manifold and the ecu?
Old 04-10-2005, 03:08 AM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
Re: ECU problem
i would'nt know but yes change the ecu, intake manifold, and distributor, for the mpfi swap. add a resistor from a si to that.
Old 04-10-2005, 08:58 AM
1PhatCX's Avatar
his cars already got mpfi tho. so he shouldnt need the resistor box or dizzy.
Old 04-10-2005, 05:22 PM
Re: ECU problem
so what all would i need to change to the SI ecu?
Old 04-10-2005, 05:29 PM
Re: ECU problem
humm, man i know you would have to have all the wiring probably since you have no ecu. cause if you don't have an ecu then you are going to have to run wires thru the firewall from the engine to the ecu. If your lucky and things happen to plug up then i am guessing that you would have to get a complete engine harness cause there are lots of sensors on the throttle body that you prob, dont have, dizzy, ecu of course, injector resistor box, intake, injectors, and thats if your lucky and you already have a harness running thru your firewall for some reason even though there is no ecu. So it would probably be a lot of wiring to pull that off but anything can be done
Old 04-10-2005, 05:52 PM
Re: ECU problem
all the wiring is there and i have an ecu but a bad one (dosnet work)
