The Swap Is A Pain In The !@#%
I can't get the axles out of my car! I need your help. What is the easiest way to get them out? I used the breaker bar and it wouldn't budge! Oh and the breaker bar broke on me! Please help me.
Are you talking about the axle nut?? If so put the car on the ground and get a nice sized ratchet and socket and then get a piece of pipe that will fit over it. Worked everytime for me. When you go to take the axles out you will need to
Undo the 14 mm bolt holding the fork to the shock. Undo the 17mm nut and bolt holding the bottom of the fork to the lower arm Take the cotter pin out of castle nut holding the ball joint on. Undo the 17mm castle nut holding the lower ball joint on. Separate the ball joint Swing the hub outward and remove the outer joint from the hub Pry the inner join away from the transmission or intermediate shaft and remove the axle.
91 civic 4dr b16a 14.8@94 |
yeah when i replaced my cv joint a while back, i had to go to homedepot and pick up a pipe that fit over my ratchet. (mine was about 6 feet
) I then had to jump on that fukker for about five minutes until the nut finally gave up. Oh yeah, be sure to bend that little tab thats on it out. then to get the ball joint separated, you can pound on the lowercontrol arm with a hammer :oi fixed my cv without taking apart the balljoint whatsoever, i wouldnt recommend it, its a real pain in the ass!!! |
i'm having trouble takin the cotter pin out
I been tryin to pull it out with the pliers and it wouldn't budge. Is there any easier way to get it out? Please help. Thanks
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
Did you make sure to bend the ends to line up with the hole on the castle nut??
this is how i'd go
get ur axel nut off, that's the hardest part w/out an impact, like they all said get a huge pipe for leverage and just stomp on it, then get a pickel fork (that giant metal fork) and slam that between ur control arm and ball joint till it breaks free and just pry down. be careful with the fork making sure you don't split the housing on your joints. if you have to disconnect your tierod end from the spinleknuckle and then you can just swing it wherever you need to, the axel will slide right out once you get a free shot at it.
formerly "riceboi" back at ph 1990 Crx Si ..b16a1 ...i/h/e ...PYR Racing head..ctr pistons .. ...flywheel ...stage 2 clutch ...3.5 drop on Ground Controls ...Koni adj's all around ... ...mugen kit ...sloppy yellow paint job ...apex'i vafc ...gsr brakes ...gsr seats ...autometer a/f gauge ...and more crap that nobody cares about |
oh yeah...that damn cotter pin....same problem as I had with mine. I tried pulling and lubing and heating that fucker up, no go. I ended up drilling it out of there
yah well if you are focusing breaker bars on it then ur gonna need a kickass impact to get it off like a snap on or ingersol rand.... the craftsman just won't cut it, if you score a good one just give it quick taps because they create the most torque at the beginning, then once you get pissed of just hold it to the bar... lol it'll come off one way or another.
My friends dad came by to help and all he brung was a hammer and a chizel! Man i'm so happy ...come on ppl lets have a group hug Now tomorrow the engine comes out! I'll keep you guys updated ! Later and thanks for the help i appreciate that
