Old 04-08-2005, 07:43 PM
Canabalooza Canabalooza is offline
Two problems
ok the first is acutally a question. is there a way to take the door appart so i can figure out why there is water dripping on my driverside front speaker. and second i have a really loud howel coming from the back of my car. i dont know when i noticed it it has been a while. could it be my tires? i slammed on my breaks about 4 months ago cause a trucker cut me off on the freeway back to portland and it flattened my two fronts but they said the backs looked ok? should i get them checked again or could something else cause the noise? i have a crx btw. thanks!
Old 04-08-2005, 07:58 PM
Scott82 Scott82 is offline
Re: Two problems
the water dripping in your car is probably coming from the door seal it's self, check it for holes or if it's not sealing good, as far as the noise, it can be tires, tires can be loud when all the tread is the same size, it will hum. make sure it's not a wheel bearing though.
Old 04-09-2005, 01:42 AM
89si's Avatar
89si 89si is offline
Re: Two problems
i have that same problem with the leaking at the speakers. its a pain in the ass to have the water in there, and the residue left after, and it cant be good for the speakers obviously.
89si-
78000kms on original engine.
sub is in.. lights are just about done..
Old 04-09-2005, 01:46 AM
Hybrid1990crx's Avatar
Re: Two problems
take your door panels off and there is shit beind it called vapor seals or something, its just plastic that keeps water from getting it. look for rips. fix any rips. wait for rain.
Old 04-09-2005, 09:44 AM
Re: Two problems
what if its all removed? there is little bits of it left but not much.
Old 04-09-2005, 02:14 PM
Re: Two problems
if its all removed then you found your problem. get some plastic and some adhesive and go to town on it.
Old 04-09-2005, 02:25 PM
Re: Two problems
k so just get plasitc and glue it to my door? that dosent make sense? how will is stop my window from leaking?
Old 04-10-2005, 04:34 AM
Re: Two problems
its not going to stop your window from leaking, but it will stop it from leaking throught speaker. replace the weather trim to fix the window leak.
Old 04-10-2005, 12:36 PM
Re: Two problems
ok cool good to know thanks a ton.
