Old 04-08-2005, 03:17 PM
adaly86 adaly86 is offline
ECU location
Hey guys, Ive a 91 Civic 1.3DX, wheres my ECU? Ive looked on the passenger side under the carpet but its not there, and the foam padding seems to be glued down, or is it on the drivers side? In ireland so drive is on the opp.
Old 04-08-2005, 03:25 PM
Scott82 Scott82 is offline
Re: ECU location
try under the other side, there is like a gold colored plate that covers it w/ 4 nuts holding it down (10mm), you can't miss it when you find it
Old 04-08-2005, 09:21 PM
stang805's Avatar
stang805 stang805 is offline
Send a message via Yahoo to stang805
Re: ECU location
it should be on the floor on the pass side, the only other place i can think of would be in the dash on the pass side, doubt it though
Old 04-08-2005, 09:23 PM
Re: ECU location
i think he has a rhd, are they on the drivers side in that case?
Old 04-08-2005, 09:36 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: ECU location
No it's still on the passenger side (the left side). Maybe it's on the side near the console, and not near the door? See if you can find where the wires go through the firewall and follow to where it goes.
Old 04-09-2005, 03:46 AM
OK still cant find it, lifted passenger side carpet as far back at the seat, its a very tight space but could not see anything like a cover with 4 screws, or under that foam padding, tried the driver side, not in main part of floor, all wires coming in that side from engine, some go along drivers side to rear of car, others go to the console but still cant find the ecu!
Old 04-09-2005, 04:12 AM
also whats this about a check engine light? my car doesnt have one, maybe my car is just retarded or something
Old 04-09-2005, 10:52 AM
CivicSpoon's Avatar
There is no Spoon
Re: ECU location
Ok there should be a plate in the center of the front passenger side. This is probably a bad expanation, but it almost looks like an upside down dust pan. Here's a pic of where it should be (only on the left side of the car): http://img.photobucket.com/albums/v4...cSpoon/ecu.jpg Also where your check engine light is.
Old 04-09-2005, 12:42 PM
ok, totally stripped my carpet back on both sides, and the padding, nothing that looks like that picture, all there is is red paint and like a black protective layer in places, nothing under the padding either, looked behind the console aswell, now the car has a fuse for an ecu but if i remove it the car will still run ok, also there is no check engine light,
the only wire that come from the engine go in the drivers side, then a branch of them comes out and goes to the passenger side and back out to the engine, the alarm was connected to one connection but there are 2 others which where never connected to anything
Old 04-09-2005, 09:30 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
Re: ECU location
I Don't KNOW Could It Be In The Trunk Or Back????if Not Maybe It's In The Dash.
Old 04-09-2005, 09:38 PM
Re: ECU location
can you post some pics of what your looking at. Where do the majority of the wires go thru the fire wall from the engine bay. Try and follow them.
Old 04-10-2005, 12:20 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Re: Re: ECU location
what he said
Old 04-10-2005, 03:01 AM
88ReX 88ReX is offline
I'm thinkin' he might not have one if he has that carbed engine.
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
Old 04-10-2005, 05:01 AM
Well I cant see anything at the back of the dash, nothing that looks like that picture before anyway, There are some cables going down the back with the speaker wires but i think they just for the rear lights, ive tried tracing the main cable that goes in from engine area but it branches to the fuses, to the back and then back to the alarm but there are also 2 other connectors which are free, similar to the one that connects to the alarm and with fuses before them, two 10amp and one 7.5amp, whats really annoying me is if the car mightn't have one why is there a fuse for it?
Does anyone know where i can find out if it actually has one, or does anyone have a similar car?
91 Civic 1.3 EDM DX (also called LX), single carb, D13B1 engine, EC8 chassis,
http://www.civic4g.com/specs.htm
Old 04-10-2005, 04:19 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
Re: ECU location
a carbed engine does not have an ECU, or a check engine light because it doesn't need it, the carb controls to the fuel and that's about it. I think it has something called an ECM or something that runs the relays for electronics in the interior...not sure, but no ECU.
