Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 04-08-2005, 02:19 PM
kingosiris kingosiris is offline
Question 95 Jetta Cluster lights out...please help
I have a 95 Jetta 2.0 and the cluster lights behind my spedo/tack/gas/and temp are out and i need help getting the cluster out does anyone know how or a site that can direct me on how. Help is much appreciated!
Old 04-14-2005, 02:10 PM
amorton amorton is offline
Re: 95 Jetta Cluster lights out...please help
I've become good at this...bulbs would blink when I hit a bump...
1. Pop out piece of plastic to the left of headlight switch, then remove headlight switch with a small straight bladed screwdriver. This should reveal one philips screw- take that out.
2. On the other side of the cluster, remove the piece of plastic that has the little bump, or heated seat control if you have that. That should reveal another philips screw-take that out.
3. Now that you took the two philips screws out, the trim around the cluster should be loose. Use both hands, palms up, grab the top part and pull out. It will pull hard, you'll feel like you're going to break it.
4. Once that is out, you should see two screws holding the cluster into the dash, can't remember top or bottom. Once the screws are out, pull the cluster out slightly, reach behind and unplug probably two plugs.
If you've made it this far, you'll figure out the rest...good luck.
Old 04-25-2005, 06:51 PM
Thumbs up Re: Re: 95 Jetta Cluster lights out...please help
Sweet man, thanks for the help. It worked like a charm!
