Old 04-08-2005, 01:58 PM
PyRoTeKniKz's Avatar
PyRoTeKniKz PyRoTeKniKz is offline
Send a message via AIM to PyRoTeKniKz
Specific clearcoat on CF questions..
Hey all, I need to know two things:
1. Will Plasti-kote clear work on SMS Carbon decal?
2. Will Tamiya Clear work on top of Plasti-kote paint?
Thanks,
Nabil
-Nabil
Projects:
Aoshima Junction Produce Lexus GS - 65% Completed
Fujimi Spoon Honda Civic EK9 - 90% Completed
-Lookin for Work Meister S2 wheels..PM me-
Old 04-08-2005, 02:05 PM
Vric's Avatar
Vric Vric is offline
Re: Specific clearcoat on CF questions..
yes and yes.
All the clear I tried over CF decal turn out ok.
Old 04-08-2005, 02:13 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
I'd be very careful, some of those "acrylics" in spray cans (Plasticote, Kylon etc.) can be very hot, enamels and lacquers even hotter.
Testors Topcote enamel should be compatible.
I have also used the Testors Glosscote and Dullcote lacquers over them in light coats with good results.
If you're talking about the X acrylics, yes.
If you're talking about the TS Lacquers, again most likely hotter than the Plasicote.
I'd avoid it.
Testors Topcote enamel should be compatible, but it does have an amber tint noticeable over white. You might get away with Glosscote lacquer, but you should test and give enough time for the paints to cure before committing them to a model.
Rule of thumb is not putting lacquers over enamels... - Mark
Old 04-08-2005, 02:17 PM
Thanks alot guys.I'l probably just get plasti-kote clear and do light coats.
And i'll be sure to test before I spray!
-Nabil
Projects:
