Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 04-08-2005, 01:52 PM
johnbell johnbell is offline
Send a message via Yahoo to johnbell
Axle Swap
I bent one the tubes (3 degrees) OOOPS on the stock dana 35 rear axle in my 95 Wrangler and am swapping it with a Chysler 8 1/4, from an 85 cherokee w/32k miles. The gear ratios are both 3.55 so no problems there. Ive had all the bracketry transfered, but I need to disable the ABS system because the new axle does'nt come equipwed w/ABS. I will just pull the fuse for now, but would like to know how to bypass the sensors. Can anyone help?
Old 04-10-2005, 09:23 AM
xj31 xj31 is offline
Re: Axle Swap
by not having the sensors,the abs is not going to work so it would,in effect,be disabled.The light will be on but you probably already knew that.
