Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 04-08-2005, 12:40 PM
phlyx phlyx is offline
Red face Canadian Made Monte SS - AC HELP??????
I have a Canadian made 2000 Monte Carlo SS and went to hook my air conditioning recharge kit up and the only port I saw was driver side under hood near front *BUT* the fitting on the line is BIGGER in diameter then the connector on the end of my recharge kit. Does anyone know if this is the wrong (high pressure) line or did the tricky Canadians use a different size recharge port on their AC units????
Any help would be greatly appreciated!
Scott
Old 04-09-2005, 09:48 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Canadian Made Monte SS - AC HELP??????
I believe the fitting you're looking for is near the air filter assembly, just behind and almost under it.
Old 08-28-2005, 08:07 PM
drvlit247 drvlit247 is offline
did you ever figure this out? i am haveing the same problem
Old 09-01-2005, 12:44 PM
montecarlossfan montecarlossfan is offline
the correct port is on the firewall on the drivers side,,,..i charged mine last year ...what a difference, make sure u habe the proper hose to charge it.., it shouldnt be bigger, its an r134a only fitting so nobody puts r12 in by accident
