Old 04-08-2005, 12:16 PM
pacethis pacethis is offline
Replace speakers only; 03 Silverado w/ BOSE
Hi everyone,
I need to know what I need to do to wire up infinity aftermarket speakers to the BOSE head unit on my Silverado. Does anyone have any info on this?
THx,
Josh
Old 04-10-2005, 03:50 PM
airtight_python airtight_python is offline
Re: Replace speakers only; 03 Silverado w/ BOSE
Umm.... couldn't you just remove the door panels and cut the factory wires to wire up the Infinity's. If you dont want to cut the wires, Crutchfield has adapters that plug into the factory plugs and give you extra wire to wire up the aftermarkets.
Old 04-10-2005, 07:40 PM
Moose is loose Moose is loose is offline
The Bose speakers are 2 Ohm. Make sure your aftermarkets are also 2 ohm or your head unit will be screwed.
Old 04-11-2005, 01:35 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
you can put the infinity's in but they are gonna be a 4 ohm instead of a ohm load. so they will draw half of the power that the stock does. so your volume won't be as loud. it should have no effect on the headunit or anything. the best thing to do would be replace the head unit and run new speaker wire to the speakers.
