Go Back   Automotive Forums Car Chat > Saturn > Ion
Old 04-08-2005, 11:35 AM
Pat_OD's Avatar
Pat_OD Pat_OD is offline
Changing Oil Ion Sedan
Has any1 done this is there anything different then changing oil in a regular car? how do i reset the change oil light?
Old 04-08-2005, 11:48 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Changing Oil Ion Sedan
i have not but- the oil reset button is ether inside one of the fuse boxes or done thru the gauge cluster, check your owners manual. also, the oil filter is an internal paper type, not the typical cartrige style. you will find ether a black plastic or aluminum cover near the intake manifold, the filter is inside there. you will need a special socket for it, i *think* its about 1-1/4", some auto parts stores list it as "GM Ecotec oil filter cover socket" or something like that, depending on where you shop.
