Old 04-08-2005, 11:11 AM
nickydontcutem nickydontcutem is offline
Angry Damn oil cap!
Man I changed the valve cover gasket and put a new oil cap on my 96 gst and it still leaked through the oil cap. Could anyone let me know something that I can do to stop it from leaking there. My car is startin to piss me off.
Old 04-08-2005, 11:39 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Damn oil cap!
I think I remember someone saying that they ended up using 2 gaskets under the oil cap to keep it from leaking. Might want to do a search on that.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-08-2005, 11:47 AM
silverstrike silverstrike is offline
Re: Re: Damn oil cap!
Yes, two gaskets should work, sometimes its just a bad fit, not all oil caps are perfect. Just pull one off of another cap and throw it on, see if that works. If not, Duct tape! not really, j/k
Old 04-08-2005, 01:03 PM
ok, thanks I'll try that guys. Hopefully it works.
Old 04-08-2005, 04:37 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
Re: Damn oil cap!
tighten the screw on the underside of the cap. that worked for me somehow
Old 04-08-2005, 05:19 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Damn oil cap!
you could just buy a new oil cap from the mitsu dealership for $13.50
DSM geek
Old 04-08-2005, 10:40 PM
macder macder is offline
Send a message via MSN to macder
Re: Damn oil cap!
I find the gasket on the cap hardens from all the heat, i'm on my third cap. I just went to the junkyard one day and took 6 caps of different dsm's.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 04-10-2005, 07:59 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Damn oil cap!
Tightening the screw only works if its leaking because the screw is loose. I bought a new cap, AND bought a second gasket. Havent looked back in the last 4 years. Bought the 91 daily driver with the fancy polsihed cap, and it goes on way too easy. Oil all over the engine bay. Swapped in the trusty old cap off the 2g, no more oil loss. Goes on nice and hard too. You really have to put some ass into it. I think an extra gasket is only about a dollar. They were so cheap chad bought a bunch and just gave me one.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-10-2005, 08:11 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Damn oil cap!
I had that problem and doubled up the gaskets.. yup... put some ass into it!!!! worked like a charm
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
