Old 04-08-2005, 10:57 AM
DJPaul DJPaul is offline
RSX/Civic Chop
I am thinking of swaping front ends on Fujimi:
and
Where would you guys recomend to do the cut:
1. Just cut out the head lights
2. headlights and front bumper
3. Right in the middle of wheel arch
4. at the windshield
5. elswere (your idea)
Thank you very much.
Paul
Old 04-08-2005, 11:16 AM
TheBenzon TheBenzon is offline
Re: RSX/Civic Chop
the question is which frontend is going on which car
Old 04-08-2005, 11:46 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: RSX/Civic Chop
Right behind the back of the wheel well.
-Mike
Old 04-08-2005, 12:27 PM
AstroRide44's Avatar
AstroRide44 AstroRide44 is offline
Re: RSX/Civic Chop
id say at the front of the door and then up to the windshield.
"You can go far with a smile, but you can go farther with a smile and a flamethrower"
Keep it Wingless.....
Old 04-08-2005, 02:06 PM
Re: RSX/Civic Chop
That's gonna be some ral challenge for me. I am thinking of swapping front ends on both cars: Rsx w/Civic front and Civic w/RSX front. Mine main concert is the body line that is on the car: Civic has one that is real sharp one, where RSX is kinda roundish.
Old 04-08-2005, 03:24 PM
Amazon's Avatar
Amazon Amazon is offline
Re: RSX/Civic Chop
It`s a complicated process. The fronts probably have different curvatures everywere. But one thing i´ve read ( altough it was on sectioning) was to make the cuts on the sides were the panels are as straight and vertical as possible.
Newsflash: Diecast sales fund terror activities.
Old 04-08-2005, 03:47 PM
Re: RSX/Civic Chop
id say ask willmo... he will know what to do.
Old 04-08-2005, 05:07 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Re: RSX/Civic Chop
This will be a much more comlicated process than any other Honda front end swap. The DC5 and the EP3 do not have nearly as much in common as the EKs had with the DC2 and the E?s had with each other. More reason to hate the EP3.
Comparing the two bodies:
The bad news:
The wheel arches are in very different spots in relation to the windshield.
Due to this, the character line on the hood is very different.
There is about double the overhang in front of the wheel arch on the DC5 than the EP3.
The door shapes are very different, the A pillars are very similar.
The DC5 is .1 inch wider at the wheel arch, and its hood is .05 inch wider at the wheel arch.
The good news:
The body/chassis attachement point it at the same place on both models, so using the EP's chassis under the EP's body with the new front clip will snap right in place once you've done the body work, and vice versa.
I probably wouldn't suggest this, but if you have to perform this conversion, your best bet would be to cut the cars just through the centerline of the wheel arch (this will go right through the windsheild washer nozzles) and swap the clips there. You will have to do a ton of work blending the fenders, and more to blend the hoods, but this is the only way to do it without absolute major surgery to the kits.
Old 04-08-2005, 10:45 PM
Re: Re: RSX/Civic Chop
The bad news:
The good news:
see thats what i'm talking about... do what he said.
Old 04-11-2005, 10:11 AM
Re: RSX/Civic Chop
Thanks, guys. This is very crazy idea, and also a good test and lesson for my skills as well.
Thanks a lot for all the words of wisdom
