Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 04-08-2005, 10:09 AM
adblink182 adblink182 is offline
Caliper Removal
do you need a special tool to remove the caliper? I'm looking back there and it isnt just a regular bolt, you need something that will actually go inside of the hole to get it off?
how the hell do you do it?
Old 04-08-2005, 11:04 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
It's a hex wrench (more commonly called an Allen wrench). Any auto parts store carries them in a variety of shapes/forms, wrench, socket,l-wrench, etc. Ask at the parts store for a GM Caliper removal wrench.
Approximate size is ,375 in or 10mm, someone can correct me if I'm wrong.
Old 04-08-2005, 11:50 AM
Re: Caliper Removal
ya I thought thats what it was...dammit....already went to the store to buy a bigger c-clamp cause I figured when I pushed the piston back and the bolts came out, they would be regular ones....clearly not
looks like another trip to the store! blah
Old 04-08-2005, 09:17 PM
hotbug1776's Avatar
hotbug1776 hotbug1776 is offline
Re: Caliper Removal
Some are Torx bolts as well, mine are. if it is Torx (star shaped), then it will most likely be a t-50. If it is DO NOT use an Allen in it, you will damage it most likely.
And remember 38 Ft. Lbs torque ,please, on those when putting them back on.
Old 04-15-2005, 09:02 AM
Re: Caliper Removal
this doesnt make any sense!
I tried a T-50 (too small) and then a T-55 and T-60 both TOO BIG! wtf is going on!
//edit ah dammit thats why! its NOT a torx bit! its a hex, 3/8!
Old 04-15-2005, 10:45 AM
hotbug1776's Avatar
Re: Caliper Removal
see how GM make's us have to work harder for the cars we cherish.
