Go Back   Automotive Forums Car Chat > Peugeot > 205
Old 04-08-2005, 05:34 AM
jtonky jtonky is offline
Question pug 205 wiring colour diagram
Hello, i have a 1993 pug 205 scepter (1.4 5 door hatch). It has central locking and i want to wire in a remote unit so i can have remote central locking...
Does anyone know where the central locking control unit is? Also dose anyone know where i can get hold of a wiring digram which shows what colours what and where what goes where to so say. If u know any good sites or anything, let me know, thankyou.
Old 04-19-2005, 01:24 PM
healy787 healy787 is offline
Re: pug 205 wiring colour diagram
Hi mate. get hold of a haynes manual if u havnt got one. The wiring diagrams in the back will show u all u need. Peugeot use little numbers printed on the wire to identify them. these numbers will be shown in haynes manual and show u where wires go etc.
Old 04-20-2005, 09:00 AM
Thumbs up Re: pug 205 wiring colour diagram
thanks, i had a look and they do match up!
Maybe i can do this afterall..
Old 04-21-2005, 01:28 PM
carolinepovey carolinepovey is offline
why's my front left wheel area squeaking like a mouse?And what are the recommended tyre pressures?
Old 04-21-2005, 01:49 PM
Re: Re: pug 205 wiring colour diagram
recommended pressures are 28 at the front and 30 at the back. If you open our driver side door and look on the side of the door there should be a pannel will all the info you need,
Squeaking, get a garage to have a look at it.
It could be the suspention...
CV joint/boot things - maybe the boots have split and it needs replaceing a lubricating
or it could be somthing to do with the breaks, warped disks.
Any noise is bad, and if u not get it checked it can get worse and more expensive.
Old 04-22-2005, 05:04 PM
could be just brake dust causing squeak or pistons in caliper commonly seize on 205s and cause brakes to bind.if u dont feel confident takin a look urself, take it to a garage
Old 10-29-2006, 10:14 AM
johnnyboy! johnnyboy! is offline
My rear wheel was squeaking like this. It turned out to be rubbing on the inside against the body work due to a bent axle, so you might want to check the walls of your tyres and not drive so often to avoid a blow-out.
