Old 04-08-2005, 06:14 AM
88CiViC_D-15's Avatar
88CiViC_D-15 88CiViC_D-15 is offline
Send a message via AIM to 88CiViC_D-15 Send a message via MSN to 88CiViC_D-15
sohc zc timingbelt whining noise
sence ive had my zc, got it about 2 months ago, it seems like the timing belt is making a whining noise or even the cam. any help would be nice to find out the prob. thanx
Team Lonely Drivers IS LOOKING FOR MORE MEMBERS,CLICK HERE
TLD FOURMS
- 88 civic std w/ sohc zc swap
- 88 integra ls, stock
- lookin for a 4dr. runnin or not
Old 04-08-2005, 06:40 AM
vladlos's Avatar
vladlos vladlos is offline
Send a message via AIM to vladlos
Re: sohc zc timingbelt whining noise
the timing belt is on too tight. this could lead to premature wear. you should loosen it up just a little bit to the point where you have just a tad bit more play.
Old 04-08-2005, 06:59 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
yup too tight
Team Lonely Drivers
Old 04-08-2005, 07:06 AM
should i replace it or should it be fine?
also what is the best way of tightening up the timing belt??
thanx for your help guys
TLD FOURMS
Old 04-09-2005, 12:02 AM
vladlos's Avatar
loosen up the tensioner and push on the timing belt to loosen it up or if you want to tighten it, put a wrench on the camgear bolt and turn slightly to tighten
