Old 04-08-2005, 03:31 AM
stokleyjm stokleyjm is offline
having jeep problem and need help
My 4.0/Auto 88 cherokee has almost every sensor I could find replaced all new injectors even a new starter and it will not start with out starting fluid but runs great once on the road about 19-21mpg hwy. It has spent multiple vacations at a resort for jeeps ( Jeep dealerships ) and they tell me they do not know what is wrong. That is why I have all new sensors (one at a time). Not totaly their fault my jeep is shy and refuses to act up at the doctors office (dealership) even when they keep it for a couple of weeks. Any ideas?
Old 04-08-2005, 10:10 AM
Dale Aeppli Dale Aeppli is offline
Re: having jeep problem and need help
TRY TURNING THE KEY ON AND WAITING 30 SECONDS THEN TRY TO START JEEP. SOUNDS LIKE YOUR FUEL PRESSURE IS RETURNING TO TANK IF JEEP SITS FOR A LONG PREIOD OF TIME, LIKE OVERNIGHT CAN YOU HEAR THE FUEL PUMP RELAY CLICK AS SOON AS YOU TURN KEY ON. DALE [email protected]
Old 04-09-2005, 07:52 AM
MidNightBlue's Avatar
MidNightBlue MidNightBlue is offline
Re: Re: having jeep problem and need help
I agree, which would also indicate that would have a small leak/air leak in the fuel delivery system or the gas cap isn't holding pressure or injector o-ring bad.
Old 04-09-2005, 11:13 AM
Saudade's Avatar
Saudade Saudade is offline
Does it idle smoothly once it starts? Have you checked your fuel pressure with the key on and engine off?
Try opening the throttle a little when you start. You can even remove the air filter.
Old 04-11-2005, 11:01 PM
fergmonster's Avatar
fergmonster fergmonster is offline
Send a message via MSN to fergmonster
Dale,
wasn't a problem like this one posted last year? I thought is was a wiring problem w/ either the ignition switch or fuel pump. Can't remember. can you?
-mike
Old 04-12-2005, 08:48 AM
Thanks I've tried that and nothing somebody said some thing about the ignition switch so I changed it as well. It did not fix the starting problem but it did fix my phantom excessery problem so thanks to who pointed me in that direction.
Old 04-12-2005, 09:18 AM
Re: Re: Re: having jeep problem and need help
HAVE YOU CHECK THE FUEL PRESSURE AT THE FUEL RAIL WITH A GAUGE. FUEL PRESSURE SHOULD BE39 LBS. REMOVE THE VACUUM LINE ON REGULATOR. FUEL PRESSURE SHOULD BE 8-10 LBS HIGHER WITH VACUUM LINE DISCONNECTED DALE
[email protected]
Old 04-12-2005, 09:20 AM
after the car has set for a while, is there fuel pressure at the fuel rail? by the way, are you holding on to all the "sensors" you have changed? they can come in handy if you have another jeep, or you could sell them. Not for much but you could sell them cheap.
-mike
