tire size
anyone know the biggest tire that can fit with stock height? any recommendations on tire?
Re: tire size
Hi,
what model/year do you have? Street, off-road, mud tires? 1/2 ton takes P rated tires, 3/4 ton takes LT rated tires. Denalis have bigger rims. By stock height you mean no lift kit? Please specify if you are looking for wider tires on a stock rim, bigger rims with the same diameter tires, stock rims with bigger diameter tires, bigger diameter tires and bigger rims? There are some threads about this. http://www.tirerack.com may be of help. Take care, Eggert
Re: tire size
05 yukon, 1/2 ton. yeah stock height meaning no lift kit. i've tried looking for info on the net but couldnt find any. whats the biggest tire i can have with stock 16" rims and no lift kit? for street/off road. thanks
Re: tire size
Hi,
Yukons have limited space in the wheel wells and can not use snow chains, only limited clearance snow cables. This may put a damper on upsizing. Do you want wider tires, taller tires or both? What purpose do you need them for? Take care, Eggert
Re: Re: tire size
mainly I just wanted bigger tires than stock. the stock ones look so small. and with more tread. i saw another yukon with bigger tires and it didnt look like there was any height adjustment. only tires. i'm looking for mainly taller and a little wider. thanks |
I really dont know the size that may fit your yukon. But I do suggest this tire the BF Goodrich KO All Terrain Tire. Nice look for the yukon. I have these on a 96 F-250 Diesel in size 35/12.50/R16.5 with a 6 IN lift kit. The only place where I found them at a reasonable price where at WWW.4WHEELPARTS.COM. Good Luck
Re: tire size
cool thanks.. do 4" lifts exist? i've heard of them but i cant find them anywhere. |
I think so just contact a salesperson from 4wheel parts and I'm pretty sure they will have it. I've been to their warehouse here in Los Angeles and its HUGE ! All you see parked outside their showroom is lifted trucks and suv's.
Re: Re: Re: tire size
Here is a site that will help you determine what size tire you might be able to fit on your truck. http://www.miata.net/garage/tirecalc.html |
Re: tire size
i put 33ees on my 93 yukon but i put a 4inch lift. looks great but some times it rubs. yeehaw
Re: Re: tire size
I have 305/50-20's on mine and they do not rub at all. I chose Toyo Open Country Tires to get all season and terrain traction as we use the Yukon as the family transport to the mountains during winter. They ride very well and look great. Email me if you want pics.
Re: tire size
Goodyear wrangler ats 285 70 r 16 best looking tire on market have them on my yukon no problems everyone comments on how good they look. By the way im a tire fanatic this is my life. The bfgoodrich tkos are much 2 aggressive looking for a suv
Would a 305 70/16 work on a 2001 Yukon XL ?
Re: tire size
Go to http://www.1010tires.com/TireSizeCalculator.asp It'll give you a good idea how that sizes up with the stock measurements. |
Re: tire size
I had 305 on my 97 z71 truck there was a little rubbing in turns but i dont know if the suv sits lower i did crank my yukon up an inch in front
