Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-07-2005, 11:56 PM
dufferdad dufferdad is offline
99 rodeo engine squeeling from the rear
Our 99 isuzu rodeo engine is squeeling, but the noise is coming from the rear of the motor. The noise is what you might expect from a loose belt or bearing but they appear to be all up front. The pitch does change with the RPMs. What might be making that kind of noise from that location?
Old 04-08-2005, 10:30 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 99 rodeo engine squeeling from the rear
The only think I can think of is that your EGR is plugged and is whistling
or
your intake manifold gasket let loose and and is whistling
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 04-08-2005, 08:36 PM
rodeo02 rodeo02 is offline
Bad intake manifold gasket is my guess as well. They can give off a squeal,screech,hum type noise when they develop a crack. Air gets sucked through the crack causing the gasket material to vibrate like a reed. You will notice it most at idle/low throttle (hi vac) conditions.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 04-08-2005, 11:07 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Need More Info Cant Help If I Dont Know What I Am Trying To Help With (what Engine Is Planted In This Pig)
