has anyone seen any kits for a single turbo conversion? i havent had any luck finding one... someone have any ideas or a good site?
![]() Upgrades... To many to list...
Re: Single turbo conversion
i've seen some people on 3si that have contemplated it, or actually done it. It's pretty rare, but it's been done. Check 3si out for more info.
'92 3000GT VR4 Current Mods: K&N FIPK RPS Streetmax clutch Rebuilt tranny Free Boost Mod Maximal Performance Solid Motor Mounts Pictures and Videos of my car Got a question about your auto insurance? I'm an insurance agent, ask away. |
Why single when you can go double?
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
Wouldn't certain parts of an NA engine blow if we added two turbos on it? Or will it blow with one either way?
It doesnt matter the number of turbos, just the psi your pushing and the cfm your flowwing, twin is a lot easyer to install.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions. |
single turbo's have been proven to be more dangerous on sl's but it has been done with succes.. i am going to work on one as soon as i get the body all fixed up
to slade... I think the pistons would get f'd up b/c they aren't those of the proper compression... I'm not sure about some of the other internals...
Georgey on the subject of midget beastiality pornos Quote:
R.I.P Andy, you will be missed by all. |
single turbo has the ability to push more hp. i know alot of people with supras who go single because of hp advantage... plus when you start going big on turbos there isnt enough room back there for the second turbo... say i wanted a big 76 trim... well it just isnt possible with it to be back there... plus its too hot behind the engine... haveing single turbo with have cooling advantages...
plus its alot cheaper to buy one big turbo than it is to by 2 smalls...
Hey i was wondering what your settings were for your greddy profec II I have one and i have had problems with it spiking. I know how to adjust the gain and all that i was wonder how your luck has been.
92 Stealth R/T TT CURRENT MODS: K&N FIPK Spec Stage 3 Clutch 6 Puck HKS Turbo Timer Type-1 3 Inch Polished Y-Pipe Greddy Profec B Spec II @ 12.0psi Greddy Type S BOV Greddy Catch Can Borla Exhaust 3 Inch SS Down Pipe with Race Pipe 3SX Crank Pulley Accel 8.0mm Wires Gen 3 Lifters High Flow 290lph Fuel Pump (Supra Pump) Plugs Gapped at .030 Iridium IK20's 550cc RC Engineering Apexi S-AFC II (WILL BE REMOVED NOT YET) 2 G-16 Turbos AEM EMS FUTURE MODS: Custom FMIC |
Re: Re: Single turbo conversion
me?... same problem
![]() lol good to hear im not the only one... mabey we have it hooked up wrong.
Anyone with really big twins doesnt put them in the stock location, they would go to the left of the engine.
The pistons in an NA are 10:1 instead of 8:1, it just means you will make boost sooner and more power at a lower psi, but your max hp will be less in theory. As far as strength, they are made of the same thing as TT pistons.
true but i would sujest you not put a turbo on a 10:1 engine... because youll blow it up and sooner or later and will have to get it rebuilt.
