Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 04-07-2005, 09:17 PM
teemsta teemsta is offline
is it difficult?
how easy or how hard is it to replace a passenger side front axle? i have a new one on the driverside but need to replace the other side. once you take off thr rotors and caliper, is there a spindle nut? is that all that needs to be removed or is there something else holding it in place in the houseing? any info would be very helpfull. thanks.
Old 04-08-2005, 12:00 AM
JDPascal JDPascal is offline
Re: is it difficult?
To remove either front axle, you have to remove the hub/bearing assemble. It is held into the steering knuckle by three bolts from the back side. They are a 12 point head (at least on mine). The hub can be stuck fairly tight in the knuckle even after you get the bolts out - I had to replace one of the bolts after I used it "improperly" to get the hub out.
the axle nut is torqued to 175 ftlb and the caliper bolts 15 ftlb when you put things back together.
JD
Old 04-08-2005, 03:37 AM
Cam7 Cam7 is offline
JD pretty much sumed it up. It is a litlle easier if you have a puller to remove the hub and you should remove the Wheel Speed Sensor.
Old 04-08-2005, 08:11 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
The hardest part about this is the HUB NUT/AXLE NUT. I could never get the NUT off, I broke a CRAFTSMAN BREAKER BAR trying to get it off, fortunately I didn't need to get it off like I originally thought (I was replacing the Ball Joints).
