I've tried several times to reset the message "change engine oil" according to the instruction from the manual and I still got the same message. Can anyone help me how to do it right? Thanks.
Re: resetting "change engine oil"
The button for your trip odo. Keep pressing it until the oil life is displayed. Hold the button in until it resets to 100%.
Shop Foreman Buick Pontiac and GMC dealership ASE Master Tech ASE Advanced L1 GM Master tech Licensed Aviation mechanic |
Re: resetting
Thanks for the reply. I have a 2000 montana that in order to reset the engine oil message, it requires to turn the key to "run" and push the gas petal and release slowly for three times within 5 seconds. I tried several times and the message is still on. Any helpful tips will be appreciated. By the way, does anyone know which fuse is for the message center? |
Are you sure about pushing the gas pedal?
Mine says to push brake pedal for 3-5 seconds with ignition on but engine not running. Remember to put trip/odo to oil and have button pressed at the same time also. That instruction is in the manual. |
Yewtrees, our 2000 Venture has the "gas pedal reset" procedure, which I've been able to do OK. The only recommendation is to do press the gas pedal 3 times in 5 seconds, but to do it quickly rather than slowly, making sure you use full travel for the gas pedal. That worked fine for me. Sorry, don't know about fuses for the message center.
Yewtrees, let us know if you are successful. The newer models use the odometer button to reset, so it's simplier. I wouldn't pull any fuses unless you are desperate.
OK, good for you. We love our Venture as well. And, we've found this fourm to be very helpful.
This is the OFFICIAL instruction from GM Service Manual disc set:
GM Oil Life System - Resetting Resetting Procedure 2000 Pontiac Montana Follow this procedure to reset the GM oil life system: -Turn the ignition to ON without starting the engine. -Fully press and release the accelerator pedal three times within five seconds. -If the CHANGE OIL SOON indicator flashes two times, the system is reset. -If the CHANGE OIL SOON indicator comes on and stays on for five seconds, try to reset the system again. |
