Old 04-07-2005, 08:26 PM
Forkliftguy's Avatar
Forkliftguy Forkliftguy is offline
Stock Cam Timing
Hey guys,
Anyone know the stock timing on cams for a '01 2.4l DOHC in the GA SE with the auto trans? Making headers for it but can't seem to find figures on the Net. I'm trying to calculate the lengths for the pipes and can't do it without knowing the difference in timing between the intake cam and exhaust cam. I don't want to have to go to the cams at this point in time, so any help would be appreciated. Thanks.
Marc
MECP Level 1 Installer
Mobile Dynamics Corp. Certified Installer
Clifford Electronics Cetified Mobile Security Installer
Electrician in training
'01 GA SE, Stock....for now.
SudburyGrandz
Old 04-07-2005, 08:41 PM
justin0717 justin0717 is offline
Re: Stock Cam Timing
I dont exactly understand what your talking about, if you specify i may be able to get the information for you.
1996 GA SE 2.4L- sold
1999 GA SE 3.4L - newest
Old 04-07-2005, 08:55 PM
Well, baically I'm tryin to find the valve timing for intake and exhaust. Eg: 265/274 deg. I need to know the difference in degrees between the exhaust valves and intake valves. For instance, in my example the difference would be 9 deg between exhaust and intake. HTH
Thanks,
Marc
SudburyGrandz
Old 04-07-2005, 09:03 PM
let me take a look, ill need to access the database at my college to get the information. Pm me your email and ill send it to you. But i know for a fact i can get it.
Old 04-07-2005, 10:53 PM
Sweet,
Thanks Justin! In the meantime I'll keep searching on my end also.
Marc
SudburyGrandz
Old 04-08-2005, 06:34 AM
Hoags's Avatar
Hoags Hoags is offline
Forklift, you may want to try contacting a cam manufacturer like Edelbrock, I'd be willing to bet that they cam give you OEM figures along with the figures for replacements.
Just a thought, hope it helps,
Old 04-08-2005, 08:53 AM
this database doesnt say the exact timing. all it gives is the lift. exhaust - .346 intake - .354
Old 04-08-2005, 08:55 AM
Maybe if if you try the edelbrock site you may find some info...I have all the other specs, but not the timing degrees...Sorry
Old 04-08-2005, 09:01 PM
Cool, thanks for the help Justin. I'll record those numbers because they will also help. I'll keep searching the net to see if I can dig up any info, I may have to resort to phisically checking.
Thanks,
Marc
SudburyGrandz
Old 04-09-2005, 10:35 PM
no problem, any other specs you need let me know. I have the 2.4 as well, older (96) but still the same thing, and just for the hell of it i printed all the specs so when i get to rebuilding my engine i got everything i need.
Old 04-10-2005, 09:15 AM
Sweet, it'll sure make things easier having all those specs on hand! I'm keeping my eyes peeled for wrecked GAs or at least there engines. It would be nice to have an engine on the side to do all my mods too, then just do a swap when it's done. It's kinda hard cause this one is my daily driver. Thanks for your help Justin, I'll keep the fact that you can specs in mind.
Marc
SudburyGrandz
Old 04-10-2005, 01:06 PM
no problem, thats my problem to is my GA is my daily driver so if the engine goes im SOL. But if i had another rebuilt engine on hand then id be set..
Old 04-10-2005, 01:39 PM
Well, in my searching, if I ever come across stuff like an engine or whatever I'll keep you informed. It's hard to find good deals or rare finds.
Marc
SudburyGrandz
Old 04-10-2005, 07:39 PM
thanks, what i really wanna do is get the cams from the 2.3 and install them (i know its a specific 2.3 that they come from).
Oh and did you know that they already make a header for the 2.4? I forgot to metion that.
Old 04-10-2005, 07:41 PM
http://www.streetbeatcustoms.com/str...pas701278.html
