Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-07-2005, 08:08 PM
2kCivic_GSR's Avatar
2kCivic_GSR 2kCivic_GSR is offline
Exclamation Engine Help!
Hey everyone I needed help figuring out whats wrong with my motor. I have a b18 C1 swap into my 2000 civic and it has trouble starting. Every time I turn on my car after letting my car sit for a few hours, the motor struggles to start, then it kicks on. But when I drive the car, shut it down, then start it again about an hour later it starts smoothly. I was wondering if it could be my ECU? or if my regulator isn't pumping enough fuel? Below is a list of what I've done to my motor so far and what I've recently replaced. Please help if you can. Thanks.
Engine:
AEM CAI
AEM fuel rail and regulator
DC headers
Replaced recently:
Spark plugs and wires
power steering pump
oil and filter
Old 04-07-2005, 08:59 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
Re: Engine Help!
Try Fuel Filter, If Its Clogged You Might Need One.
Old 04-10-2005, 02:19 AM
bob stone's Avatar
bob stone bob stone is offline
Re: Engine Help!
umm dosnt honda got that chip in the distrubitor cap ( my accord had one go bad and the car would just die a lot and not start for a while but then it would run fine ) any ways dont know if you got it but my mech told me they have a tendency to get dmaged from heat and would fail a lot ?
Old 04-10-2005, 01:37 PM
Re: Engine Help!
Im not quite sure if there is a chip in the distributor but i already checked for spark and everything is just fine. The fuel filter clogged? I never considered that....but ill be sure to give it a shot. Thanks for the posts.
Old 04-10-2005, 05:19 PM
bob stone's Avatar
Re: Engine Help!
it wont affect spark it just starts to fail then start working again, it is right in the distrubiter cap it self. but this is mostly i guess about you issue, I would also check up on that fuel filter mentioned.
Old 04-10-2005, 05:47 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Engine Help!
cap, coil, rotors, wires, plugs, fuel filter.
the basic maintenence stuff.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 04-10-2005, 09:55 PM
Thumbs up Re: Engine Help!
You Can Also Ugrade To An External Coil,W/ A MSD CAP Always A Plus...
