I have a 96 Intrepid. After disconnecting the PCM and plugging it back up the car won't start. There is only about 2.2v at the crankshaft sensor instead of 8v. There is no voltage to the coil pack. The fuel pump is pumping gas but no spark. Please help.
Re: 96 intrepid
If you disconnected the PCM WITH the battery still hooked up, you probably have puked your PCM.
Daily Overhauls Do Get Expensive Dangerous On Days Gears Engage Dead On Day Guarantee Expires Dead Or Dying Gas Eater Department Of Defense Garbage Equipment Dodge Owners Don't Get Excited Don't Overdrive Gutless Engine Drips Oil Drops Grease Everywhere 1995 Dodge Dakota SLT 3.9 V6 1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4 |
Re: 96 intrepid
The battery was disconnected. Tried a different PCM but it would not start either.
Re: 96 intrepid
what size of engine do you have the cam sensor shares the same 9 volt circuit if equipped with a 3.3L check the harness at the valve cover on the front passengers side sharp edge shorts harness there and if ok try disconnecting cam sensor and recheck voltage
