Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - Air Cooled > Type 1
Old 04-07-2005, 06:27 PM
Rick's69's Avatar
Rick's69 Rick's69 is offline
Send a message via AIM to Rick's69
transmission problems
My 69 beetle has been working correctly until yesterday when i was driving in 1st gear the shifter shifts to neutral. and its been doing that ever since. I changed my tranny mounts but ill check them and other ideas?
Old 04-07-2005, 08:40 PM
trooperbrett trooperbrett is offline
Re: transmission problems
Is it the original transmission or a rebuilt one? I had a '67 with original trans that popped out of gear in 4th, I tightened all trans mounts (rear and nosecone) and I think I remember changing the rear mounts (it's been 20+ years) and changed the gear oil. That fixed it for me, good luck.
Brett
Old 04-10-2005, 11:10 PM
Rick's69's Avatar
My gear oil is full and my mounts are all brand new, it still just pops out of gear. Any other ideas? what is the linkage? could that have anything to do with it?
Old 05-17-2005, 12:55 AM
PYROMANIAK777 PYROMANIAK777 is offline
Re: Re: transmission problems
Check your shift coupler, you can find it under your rear seat, remove the tunnel cover, and you'll see it. Make sure the rubber is in good condition, if you're not sure, just replace it, cause it's pretty cheap. removal and installation skill level from 1-10 requires a 2. Is there a lot of play in the shifter? that would be one indicator of a coupler going out. The original ones had rubber between 2 metal pieces, but you can get an upgrade that is all metal w/ rubber inside I believe, not very expensive, but will last way longer, especially if you crank on that shifter.
If that's all good, then call "Old Speed" in Paramount, CA the guys there are really cool and helpful.
Old 08-02-2005, 12:00 AM
voggy voggy is offline
Dear all,
Seems like i m having the same problem as trooperbrett. I ma a new beetle lover and after changing the transmission oil, the 4th gear jumps to neutral when i press the accelerator harder. The mechanic suggest that the whole transmission has to be changed. I m asking him to chang the rear mounts and check the shift coupler.
Anyone can give me any other suggestions as of what could be the problem ( a cheaper option perhaps, compared to changing the whole transmssion)
Please help
Brett
Old 08-12-2005, 09:55 PM
bluebug's Avatar
bluebug bluebug is offline
Had the same problem on my 72 super, but was second gear during exceleration. Rebuilt the trans and found it had a bad gear inside.
Clark
Old 09-16-2005, 09:38 PM
dgee dgee is offline
the detent balls inside the tranny are shot that why it keeps popping out of gear.
