Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-07-2005, 07:03 PM
--- --- is offline
2.25'' exhaust too small?
I talked to an exhaust shop today and they told me they would put on any muffler I wanted (that they had in-store in-stock) plus a full cat-back exhaust for $130. I thought that was a little cheap, but I'm not complaining.
And I asked about a 2.5'' piping and he told me he can't bend anything that big, but the biggest he can do is 2.25''. Is that going to produce any power on a NT motor or should I go for something bigger?
I drive a slow car.
Old 04-07-2005, 07:23 PM
silverstrike silverstrike is offline
Re: 2.25'' exhaust too small?
Hey, if you are looking for power, try to stay away from a bend that will reduce the diameter of the pipe. It may be a little more expensive, but if you get the exhaust done custom and can get it mandrel bent, you will get more power. Basically instead of just popping it in a machine and bending the pipe, it has to be filled with sand, then bent. This will keep a continious diamter without kinking it at the curve.
Old 04-07-2005, 07:53 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
2.25 will do fine with nt but bend it like ^ he said
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 04-07-2005, 08:01 PM
--- --- is offline
That's what he was telling. He can bend the pipe without crimping the tube any up to 2.25'', but after that it bends, which is why he can't do 2.5'' piping.
I drive a slow car.
Old 04-07-2005, 08:12 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
I think he is saying that 2.25'' won't kink bad, but anything larger will. I bet he is still using a press bender, which is not the good method. 2.25 should be fine on an n/t anyway.
Old 04-07-2005, 08:22 PM
--- --- is offline
Alright, thanks.
I think I'll probably go have that done after the car is out of the shop, along with a generic intake pipe + K&N Filter and some plugs and wires.
I drive a slow car.
Old 04-08-2005, 08:22 AM
GSXracerGuy GSXracerGuy is offline
Send a message via AIM to GSXracerGuy
Re: Re: 2.25'' exhaust too small?
Damn.....all the shops around here gave me quotes for JUST a muffler at $215
1995 GSX M/t 87k[IMG][IMG]
Gotta lotta work to do.
[IMG][/IMG]
Old 04-08-2005, 04:08 PM
--- --- is offline
That's what I was expecting it to be...$200 and up, I nearly shit a brick when he told me it'd only be that much. I think I'm going with the 2.25'' piping with a 3" tip.
I drive a slow car.
Old 04-08-2005, 04:18 PM
Just so you know, if you dont go with the mandrel bent pipe, a 2.25" pipe will give you the power equal to mandrel bent pipe with about a 1.75" Diameter. If you want power. go with a mandrel bent pipe, otherwise it will simply reduce your power.
Old 04-10-2005, 06:45 PM
Whathits14 Whathits14 is offline
You can still make power with press bent, but need larger diam piping, like 3 in. Mandrel is better tho, but can be done with 3 in press bent.
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 04-12-2005, 04:21 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Wow that is a pretty good deal. Is that catback? does that include a muffler or what? include installation? is it Stainless Steel?
thanks!
Alex
"You can have everything in life you want if you will just help enough other people get what they want."
Old 04-12-2005, 09:58 PM
--- --- is offline
It's a cat-back exhaust, includes muffler, and they will make it and install it for you right then.
Not sure about what it's made of yet. After I get the front of the car fixed and out of the shop I'm going back over there to see what they're made of, and what they use to make them.
I'll keep you posted.
I drive a slow car.
Old 04-21-2005, 01:06 AM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
For that price, just get a dual exhaust... Even if a 2.25'' crush bent is equal to 1.75'' mandrel, you'd make power with a dual 2.25'' crush bent cat-back exhaust. ...unless you get a turbo, that should be more than enough.
Old 04-21-2005, 01:33 AM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
There's only one exhaust manifold, so there can't be a "dual exhaust". The pipe would be split somewhere. And wouldn't improve performance only looks.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 04-21-2005, 10:39 AM
Kuhn's Avatar
No offense, but even though there's only one exhaust manifold wouldn't splitting it either after the manifold, or after the cat, decrease back pressure; therefore, increasing the possibility for hp? ... I agree that just welding an extra tube close to the first muffler would only be for looks.
He could also do what I'm in the process of fabing... I'm making an exhaust manifold that connects two cylinders to each of the exhausts. Even then, it's a good idea to have an H pipe (connecting the two exhaust tubes) to even out pressure...
