Old 04-07-2005, 05:10 PM
MaxBURNOUT MaxBURNOUT is offline
Send a message via AIM to MaxBURNOUT
Cant locate the fill area for the trans. on my car.. its a stick shift.
... I know that I sound like a compleate idiot asking this question but the reson that I ask it is becuse I see area above the drain plug that looks like it would be a fill area but when you take the racet and get it to come loose and go to fill it.. even if its empy it kick the oil out like its full. I had to fill it up at the drain plug and im not sure that I have enought in there,, with I go through where I would think that I go its like there is somehting big and metal in the way.
Old 04-07-2005, 05:11 PM
Scott82 Scott82 is offline
Re: Cant locate the fill area for the trans. on my car.. its a stick shift.
mine on my car is under the starter, or you can take out the level plug and rig you up a hose to the bottle and squeeze it in there.
Old 04-07-2005, 06:35 PM
I have a haynes book but it doesnt have anything about it.. and I kinda need some pictures that I can look at to use for a refrance..
Old 04-07-2005, 07:07 PM
it in the haynes manual, under the drive train section, look in your index in the back
Old 04-07-2005, 07:09 PM
is this an automatic or stick, and what car and what year?
Old 04-07-2005, 08:46 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
If It A Dx Manual, To The Left And Up Of The Trans Drain Plug ---- 17mm. Open End Wrench.
Old 04-08-2005, 11:47 AM
Stick.. looks like a 50cent peace with a square in it.? I opend that.. and its kinda blocked off
Old 04-08-2005, 11:50 AM
In the manual it has,,,
dash board
differential
disk brakes
distributor
door
driveaxles
drive belt
driveshaft
drum brakes
Old 04-08-2005, 12:04 PM
I found it... Yeahhhhh thanks guys... only one issue... How do i get fluid in there and is there any spicific stuff that you suggest.. I have some slick 50 Gear lube... Is that good?
Old 04-08-2005, 12:05 PM
Its a tight area...
Old 04-08-2005, 12:31 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
use gm synchromesh or honda mtf.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 04-08-2005, 02:36 PM
88ReX 88ReX is offline
troof
If you are looking for something to help you get the tranny fluid in there they sell a special funnel just for this job at your local parts store. Its like a normal funnel only it has a hose attached to the end of it and even the fancier ones have a shutoff valve on them. Good luck!
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
Old 04-08-2005, 05:05 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
what i do is use copper pipe with a 90 elbow in it, put that in the trans, put a funnel on the pipe, and fill
Old 04-08-2005, 08:43 PM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
I used air hose and ran it through the funnel flared the end out so it wouldnt leak.....No problems for me...
89 DX: LS Powered
88 CX: Project ZC
Old 04-09-2005, 12:47 AM
Very Smart!!!!!!
