Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-07-2005, 04:05 PM
jp139x jp139x is offline
Now won't start
The other day my 2001 Rodeo 3.2L V6 turn off when driving. Took a couple of minutes to restart and finally did. After getting it started the check engine light came on. Engine was running rough, loss of power and sputtering from sound of misfiring. The next morning start it up and had the same problems. Took it to Autozone to have the cel read. The codes were P0300. On the way home turn off and now will not start.
Old 04-07-2005, 06:23 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Now won't start
how many miles do you have on your plugs?
Also, it could be the intake manifold gasket.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 04-07-2005, 07:54 PM
About 5000 miles. But change already, also changed fuel filter. Someone suggested that could be the problem. Will try intake manifold gasket.
Old 04-07-2005, 08:35 PM
Isuzu Guy
Re: Now won't start
what brand of plugs?
It could be bad gas.
Water in the gas (add a can of HEET)
clean up your ground connection (to the body and to the alt bracket).
-Ryan
Isuzu Moderator
Car Show Tips
Old 04-12-2005, 05:35 PM
Change the IMG today. Still won't start. Seems like a ignition problem. Like it not getting a spark.
Old 04-12-2005, 06:11 PM
Isuzu Guy
Re: Now won't start
did you try to jump it?
Maybe there is a cell in the battery shorting out?
-Ryan
Isuzu Moderator
Car Show Tips
Old 04-12-2005, 08:21 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: Now won't start
let me guess someone at autozone told you BOSH platinum plugs were the best and would increase your fuel economy if so that is where the problem is
the only good use I have found for BOSH platinum plugs is as weights on a trout line
this engine needs to have nippendenso plugs unless someone else has foud plugs that work well with the 3.2 if so let us know once the correct plugs have been installed clear the DTC's and let me know if the light comes on if it does I will lead you to the broken wire in the engine harness
