Old 04-07-2005, 03:59 PM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
Lack of Midbass, Whats to Blame?
hey guys, awhile ago i was guna trade all my expensive stuff for lower end equipment n get outta car audio, and im almost done (waiting for the 13kv.2 to be repaired)
anyways, when i had my alpine cda-9833 and my fosgate 4ch (87rms x 4 @ 4 ohm) my cdts had alot of midbass, very full sounding
but now, ever since i switched to a pioneer 6700, and a 2ch soundstream (120rms x 2 @ 4) there is barely any midbass
my eq was always flat, and the cutoff point was always 80hz 12db slope
my speakers are in heavily deadened doors, what happened? any ideas?
the main reason i switched to a more powerful amp, was to get more midbass, but i got the opposite, i dont get why there is such littl emidbass now that i switched my equipment out
since i switched, i never touched my speakers, any suggestions?
Old 04-07-2005, 04:02 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Lack of Midbass, Whats to Blame?
I've heard that fosgate amps have build in boosts in the low frequencies to make them sound more "exciting" and "better" than other amps during a-b tests in stores, but I don't know if that's true. If so then it could easily explain it, you had a bass boost before that you didn't know about, and now it's gone.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 04-07-2005, 05:37 PM
hmm if thats true, then that might be the reason
hey sr20, do u think the way the sub blends into the soundstage can effect the way i perceive midbass?
im also temporarily using 2 10" ported jbls (prefab), until my 13kv.2 is fixed
Old 04-07-2005, 07:26 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Don't want to sound like an idiot but did you look at the obvious and make sure the fronts are not wired 180 degrees out of phase? Also, that head has a SQED effect for the front channels. It basically enhances high frequencies while lowering bass responce. Make sure you have that turned off.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 04-07-2005, 07:37 PM
sr20de4evr's Avatar
Re: Re: Lack of Midbass, Whats to Blame?
Yes, and if your kv2 was sealed that might have something to do with it. Ported generally cuts out on the upper end, so any midbass response would need to be produced almost solely by the cdts, they wouldn't have the sub backing them up. So it might have something to do with it.
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-07-2005, 07:45 PM
ah i c
hey poncho, i can't really find that effect you're talking about, do you know how to adjust that? and since its been suggested to me so many times i'll check the phase, the phase is just making sure the right/left is correct yea? thx again
Old 04-07-2005, 08:32 PM
ah i c
http://pioneerelectronics.com/pio/pe...tionManual.pdf
Look on pages 35 and 38. They don't call it what I said anymore but those pages talk about it.
Yes, you are correct. Someone with a good ear can go from the right and left fader and listen to the music. If the bass responce seems louder when the fader is all the way to the right or left, they are wired out of phase. This is simply having them wired backward from each other. So, simply swaping around the speaker wire on ONE speaker will correct this. It is a very common problem.
Pioneer 4900mp
Orion C63 Coax rear
Old 04-07-2005, 08:53 PM
thanks alot poncho, i actually found it in my manual before i sw ur link heh
anyways this is strange, in addition for the 3 band parametric eq they give u, u can add another 2 bands of parametric equalization for bass and treble emphasis
i put the treble +1 @ 2.5khz and the bass +2 @ 160hz, my speakers are now really full sounding
thanks alot
Old 04-07-2005, 08:54 PM
i'll also check the phase thing, i've never tried the method you're implying, gotta see how it sounds heh
Old 04-08-2005, 06:43 AM
No prob. Glad 2 help
Pioneer 4900mp
Orion C63 Coax rear
