Old 04-07-2005, 03:28 PM
unicyclemidget11 unicyclemidget11 is offline
whats a good boost gauge & boost controller?
Im looking to increase the boost on my stock turbos and I was wondering what would be a good gauge and boost controller.
Old 04-07-2005, 03:36 PM
Re: whats a good boost gauge & boost controller?
do i need to do anything else to safely increase the boost? i was thinkin of running 12psi
Old 04-07-2005, 04:25 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
How old are your spark plugs? I'm thinking of getting an autometer sport comp boost gauge, some people have said that autometer stuff isn;t accurate, I have some more research to do on accuracy. Anyone know on how accurate the autometer gauges are?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 04-07-2005, 05:50 PM
Igovert500's Avatar
blue + red light magnet
I've heard good and bad things about them...there are plenty of threads on boost gauges, if you do a search you will find plenty.
Boost controllers...if you look in the FAQ, you can find a link to a comparison of the more popular boost controllers written by John Monnin. His opinions are good IMO, and can be trusted. The main decision you have to make is do you want an $18 mbc that you can set and forget....or do you want an ebc that allows you to tune boost from inside the car while driving that will run you a few hundred bucks. I opted for the mbc for now.
Spark plugs, wires, and a new fuel filter and the full 60 tuneup if you are getting close to it, will allow you to run higher boost safely.
Also you can up the boost, but you wont get as much out of the few extra psi unless you get an intake and downpipe and gut the precats. With these, you will definantly notice the difference.
Lastly, why only 12psi and not 13 or 14?
12psi you can run without a boost controller. The stock 2nd gens run 12psi, and you can do the free boost mod to the 1st gens to get them up to 12psi...so if you aren't going higher...then why get the controller?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-07-2005, 06:02 PM
Boosted1 Boosted1 is offline
I've been looking alot at boost guages...OBX seems to be popular, although not yet totally proven. But I have heard good reviews so far. I just got myself a cheap MBC that I'm going to crank up to 14psi (after testing at 12), get the intake and maybe DP with my CF driveshaft...should make a decent difference. These cars have some real potential.
1993 Mitsubishi 3000GT VR4 (STOCK)
1989 5.0L Ford Mustang (MODIFIED)
http://www.cardomain.com/memberpage/761789
Old 04-07-2005, 08:19 PM
i have a first gen so stock it was like 8/9psi and i did the free boost mod so its like 9/10psi. but my car has 113K miles and i dont want to blow a gasket or anything. what should I do to tune it up. Timing belt, fuel filter, spark plugs, plug wires, what else?
Old 04-07-2005, 08:37 PM
Thourun's Avatar
Probably just plugs and check for leaks for now, why are you worried about your gaskets?
1995 3000GT VR-4
Old 04-08-2005, 11:40 AM
Igovert500's Avatar
The free boost mod puts it up to 2nd gen stock level of 11-12psi, not 9-10. This is covered in the FAQ, as is the 60k tuneup, as well as your other question about 1/4 times and hp. Please take the time to read it.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-08-2005, 06:39 PM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
Greddy Greddy Greddy all the way
Greddy makes some nice electronic boost guages and buy their Profect B Spec II boost controler
their niiiiiiiiiiice
Upgrades... To many to list...
Old 04-09-2005, 10:35 PM
Stealth-Twinturbo Stealth-Twinturbo is offline
No I did the free boost mod as well to my first gen and it went to 10 psi then droped off to 7 after 4500 rpm. That boost mod doesn't help that much. I got a profec B Spec II its ok but im holding all 12.5 psi to the redline. So its way faster upstairs. I went to the track today. Ran 13.7 @ 102.89. I expected to do better with my mods, but my 3rd gear is going i need syncros.I have an autometer boost gauge and it is off 1 psi compared to what my boost controller reads. My gauge says 1 more psi than the boost controller. So i don't know. But the new Autometer NEXUS Gauges are sick as hell.
92 Stealth R/T TT
CURRENT MODS:
K&N FIPK
Spec Stage 3 Clutch 6 Puck
HKS Turbo Timer Type-1
3 Inch Polished Y-Pipe
Greddy Profec B Spec II @ 12.0psi
Greddy Type S BOV
Greddy Catch Can
Borla Exhaust
3 Inch SS Down Pipe with Race Pipe
3SX Crank Pulley
Accel 8.0mm Wires
Gen 3 Lifters
High Flow 290lph Fuel Pump (Supra Pump)
Plugs Gapped at .030 Iridium IK20's
550cc RC Engineering
Apexi S-AFC II (WILL BE REMOVED NOT YET)
2 G-16 Turbos
AEM EMS
FUTURE MODS:
Custom FMIC
Old 04-09-2005, 11:39 PM
92VR4Red's Avatar
i have a greddy boost guage and the profec b
and the profec b is very accrate... to tell you the truth no need for a guage... but i would anyways.
Old 04-09-2005, 11:48 PM
Thourun's Avatar
Have you checked for boost leaks? Thats what those numbers make me think, my intake was full of them. The stock Y pipe and BOV suck, both were leaking on mine. Also, bad/absent spark could cause the boost to drop around there, thats also happening on mine... As soon as IPO gets me my new plugs and wires that'll be fixed though.
1995 3000GT VR-4
