Old 04-07-2005, 01:55 PM
CBURKE's Avatar
CBURKE CBURKE is offline
After Market Flywheel For Zc?
Do they make one and if so who? What yr would i need to get it from?
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 04-07-2005, 02:04 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Re: After Market Flywheel For Zc?
Any D-series flywheel should bolt right up, since it's a D-series engine...
I just happen to have one for sale over in the classifieds section
Honda Enthusiast
Old 04-07-2005, 04:37 PM
KinkBykr's Avatar
KinkBykr KinkBykr is offline
Send a message via AIM to KinkBykr Send a message via Yahoo to KinkBykr
here is a site with an aluminum one, hope this helps
http://www.kingmotorsports.com/searc...ord=ZC&x=0&y=0
Old 04-07-2005, 05:18 PM
CBURKE's Avatar
Re: Re: After Market Flywheel For Zc?
are you sure, i need to get one and i don't wanna buy it if it's not gonna fit.
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 04-07-2005, 05:43 PM
Killa_CRX's Avatar
When Civics Attack!
Re: Re: Re: After Market Flywheel For Zc?
I see no reason why it wouldn't work. Most d-series parts are interchangable... it should bolt right up.
the flywheel size is 212mm, so you'd need a 1990-1991 Civic/CRX clutch (which I also have a brand new Exedy clutch for sale too for $50 minus the throw out bearing)
Honda Enthusiast
Old 04-08-2005, 08:21 AM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
They have flywheels for 1gen and 2gen ZC's how do u know which one u have? Is the 1gen SOHC and 2gen DOHC?
Old 04-08-2005, 10:07 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
1st gens a brown top, 2nd gen is the black top
Old 04-08-2005, 12:26 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
what tranny do you have? what year?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 04-08-2005, 01:50 PM
CBURKE's Avatar
ZC. not sure what yr. It's my boys. the car is a 1991 si
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 04-08-2005, 03:09 PM
Scott82 Scott82 is offline
some d series have a recessed flywheel and some dont, i have a recessed flywheel on my 89 crx hf now w/ the d15 vtec, the d16z6 also has the same flywheel, my hf flywheel was not recessed but i believe that the clutch kits will interchange, just get the same clutch kit for the flywheel you get just to be sure, and if you have a cable trans get the throw out bearing for that instead of hydro throw out bearing
Old 04-08-2005, 03:10 PM
the throw out bearing thing if for clutch kits after 92 if they are prior to that they should come w/ the right throw out bearing in the kit
Old 04-09-2005, 03:35 PM
CBURKE's Avatar
umm well shit, i guess i am just gonna get a 90-91 clutch and flywheel and hope for the best. How can you tell what yr the ZC is?
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 04-09-2005, 03:38 PM
Mine has a stamp in betweem the exh ports that says 89. did you count the splines on your input shaft?
ZC stuff
Old 04-09-2005, 04:06 PM
CBURKE's Avatar
no but i'll do that. will you know then? i'll look at the ex ports to see what is says.
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 04-09-2005, 04:16 PM
yea, 88 has 21 splines on the input shaft, while 89-00 have 20. Also, the surface size is 88-89 are 200mm discs and 90-00 is 212mm. But if you have an 89, you can get a 212mm flywheel along with a 90-00 clutch kit and it will work like a dream.
ZC stuff
