Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 04-07-2005, 01:36 PM
PryncissVin PryncissVin is offline
Hot Temp
I have a 2000 Nissan Xterra, after driving the car for a short distance the tempature gauge begins to rise to high and when you stop to check the fluids the res. is empty. My husband thought water pump or thermostat. So he began to to change out the water pump and determined that wasn't an at home project, so he replaced the thermostat and add some stop leak. That solved the problem until now. It has started back up however this time the res. is full and the radiator is to. When I took off the radiator cap off after about an hour it looked to be foamy under it. I ran some errands and stop with the engine hot I raised the hood and opened the res. fluid full liquid not hot. I had my mom press the gas to see if maybe it bubbled, nope nothing. As long as I run the heat when this happens the temp level stays normal. There is currently water in it because the last time this happened we were out and in the middle of no where and only had bottled water on hand. There has never been any steam or smoke come from under the hood. Any ideas. my husband is deployed and Im really not up to being toyed with by a mechanic. I tried everything that I can think of!
Old 04-10-2005, 05:55 PM
PotIsYourFriend PotIsYourFriend is offline
Couple of ?'s
Is there slug on the underside of the oil cap? Or slug under the underside of the radiator cap?
Whens the last time you had your radiator completely cleaned.. And no not just running water through it then adding coolant again.. If anything take it to a place to get the radiator serviced... Should only cost 80-100 bucks... But if you were losing water you might have a leak in the radiator... But worse case the leak could be in the head or intake gasket......
Old 04-10-2005, 10:01 PM
chubbybubba1 chubbybubba1 is offline
Re: Hot Temp
Not bad advice from a pot head.
Old 04-10-2005, 11:57 PM
Re: Re: Hot Temp
Pot head, no... Wonderful plant, yes
Emporer Wears No Clothes
Old 04-11-2005, 08:36 AM
Re: Hot Temp
The slug is under the radiator cap. I have had the car right at a year and I have only had oil changes done and a tune up when I bought it. So more than likely the radiator has never been serviced. So far there are no signs of any fluids leaking my fluid levels stay accurate.
Old 04-12-2005, 09:20 PM
Re: Hot Temp
Sounds like a head gasket. Let us know what happens.
Old 06-23-2005, 01:20 PM
: Hot Temp
I apologize for the delay in the update, but here's what was discovered. Aftermy husband spoke with a young man that is cuurrently enrolled in ATI they determined is was my water pump. Not the problem! So one time when he was away I decide to take it to the local mechanic and have the problem diagnosed. Lucky for me the problem was only the radiator. There were multiple cold spots, and the inside was so gumed up that noting could circulate. So we replaced that and took it back in to finish the diagnosis, no other problems. We did a flush and fill to make sure that even with the new radiator and hoses and everything else was good. So far zero problems. Thank you so much for your advise!
