| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
motor winding?
hey iv got a 91 laser 2.0 one day out of no were my engine just started to give off a really bad winding noise. the car still runs and drives but at about 5 6 grand i loose all of my power. is my crank starting to walk? or wat could this be thanks guys. BY the way im looking for a new motor if anyine knows were to get one plz let me know.
Re: motor winding?
did you check your oil? turbo or NT? does the noise change with rpm or with wheel speed? does it change when you push in the clutch (if you have one)
put the year, make, model, engine, trans, and any mods in your sig so you dont forget
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
Re: motor winding?
its a 2.0 non turbo yes i checked my oil its a 5 speed 91 laser
Re: motor winding?
it is a 91 laser non turbo 5 speed it almost sounds like a spun bearing
Re: motor winding?
a spun bearing usually makes a knocking noise not a winding noise. does it change with rpm or wheel speed? does it change when you push in the clutch?
Re: motor winding?
could it be something in the tranny maybe? motor noises usually knock really loud, not whine. maybe a wheelbearing, or maybe something in the tranny too if your losing all your power.
Re: motor winding?
i dont think its coming from the tranny and it ant the wheel bearing. could it be a cam shaft bearing poss or is my crank walking? i think i might just run it till she blows i need a new motor anyways
Re: motor winding?
the higher the rpm the louder it gets
Re: motor winding?
does it change when you push the clutch in and out. not to doubt you but in my experience whining noises are usually from the trans or wheels
Re: motor winding?
6 bolts came in 89-92's so you don't have to worry about crankwalk
I have never ever ever seen a 6bolt crankwalk. But the winding I have no idea what it could be...bearings sounds like a good bet, but go take it to get checked out to be sure.
Need a GOOD 6-bolt engine? Quote:
'95 Talon Tsi EVO III GT, supporting mods, not running Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped. |
Re: motor winding?
ok thanks man ill have it looked at as soon as i get back from md jersey and pa then ill havew it look at and i think i might have her sold i hope my buddy had a 90 eclipse and he had crank walk i hear the american version sucks really bad and basicly as soon as u get the car to order a mototr from japan wat do u think
