Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 04-07-2005, 10:09 AM
yamika23 yamika23 is offline
Unhappy Coolant Leak
Hello! I am in need of some help. My 1999 SL1 is leaking coolant. It started small and would last an entire day. Last night, I filled the tank completely and this morning there was coolant all over the parking lot. Any suggestions of the first place to look for leaks? Thanks!!
Old 04-07-2005, 10:21 AM
peppermrj's Avatar
peppermrj peppermrj is offline
Re: Coolant Leak
I would check at the tank first. always look for the highest point.
Old 04-07-2005, 11:52 AM
mysatilac's Avatar
mysatilac mysatilac is offline
If you can't locate a leak, there are UV dyes you can add to coolant,
once some has leaked out, use a black light and your leak should be apparent.
here is one place you can get it ~$11
http://www.monstermarketplace.com/Ho...g893a6363.html
It's beautifully destructive isn't it,
'97 Maroon SL1- Bored Throttle Body, Knife Edged Throttle Plate, Short Ram Intake 3" Cone Filter, Flip Flop Trunk, Red Enameled Engine, Interior & Exterior Painting Mods, 4" Burnt Tip Muffler, DRLs ON A SWITCH!, "Rims", Seat Covers, And A Stereo System Thats Too Good!, Other various mods and detailing...
Old 04-07-2005, 10:37 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Coolant Leak
two common leak areas are the water pump and top left of the radiator.
Old 04-08-2005, 01:26 PM
jgeib jgeib is offline
My 97 SC2 started Leaking on the radiator. From the front of the car looking toward the motor it was about 6 inches down on the right side of the radiator. The radiator is half plastic and it just failed and began to leak. I put a new radiator in with the help of a shop manual in about an hour and a half. New radiator cost about $125 for mine. Just trace hoses and look all around once the motor is warm and the system builds a little pressure. You'll find the leak if it's leaking that much.
