Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-07-2005, 08:14 AM
nsheaffer nsheaffer is offline
Defrost vents always on.
Why is my defrost vents always blowing air? No mater which vent position I have the air turned to, the defrost vents are blowing the most air. also when I step on the gas the air stops blowing completely.
All help is greatly appreciated.
Old 04-08-2005, 10:27 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: Defrost vents always on.
the vent selection is vacume controled, chances are that you have a bad vac line or connection someplace. could also be a bad vac switch or motor. also, there is a TSB about the check valve that is between the engine and the switch, I'll see if I can find it, basically what it envolves is puting in a larger/better check valve.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 04-08-2005, 02:21 PM
galea_joe galea_joe is offline
OK stupid question - What does TSB stand for?
Old 04-08-2005, 03:09 PM
TSB= Technical Service Bulliten
it's what dodge sends out to the dealerships so that the techs know how to diagnose and fix a particular problem.
all TSBs are submitted to the NHTSA, here's theire web address, http://www.nhtsa.dot.gov/
I belive they have a search feature that allowes you to search for TSBs for your particular vehicle.
Vehicles:
1987 Grand Wagoneer
