Old 04-07-2005, 02:36 AM
adaly86 adaly86 is offline
Ticking from Engine?
Hey guys, have 91 civic dx 1.3, have noticed for awhile that there was a ticking coming from the engine, usually i only heard if for awhile after start up until it ran for a bit or when it was at the normal temp after driving for awhile, now i hear it most of the time like in 1st second and sometimes 3rd untill driving fast, also sounds like a bit of a rattle and increases with engine speed but the loudness stays the same, any ideas on what i could be? the engines got 131,000 miles on it most of it stock so i guess its kind of worn at this stage, is this something i should worry about?
Old 04-07-2005, 09:32 AM
Scott82 Scott82 is offline
Re: Ticking from Engine?
Adjust your lifters for your valves and see what ya get after that, get a repair manual for your car and it will give you torque specs and a how to on the job, you might want to replace the valvecovergasket after you get them adjusted just so you don't have any leaks after putting the valve cover back on. Good luck
Old 04-07-2005, 03:34 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
Try The'' How To'' Forums There's Something Similar There.
Old 04-07-2005, 03:43 PM
V-K V-K is offline
Send a message via AIM to V-K
I have the same issue with my car (D15B NON-VTEC)
It doesn't tick when it's cold, so this could be just something out of adjustment, and not a bent valve? (bent valve would suck, motor is only a year old)
Old 04-07-2005, 03:48 PM
Cool Re: Ticking from Engine?
Check The Haynes Manual, Or Any Other Manual, Its Called Valve Clearance Check And Adjusting, It'll Require A Feeler Guage, A Flat Head Screw Driver, And A 10mm Open Wrench.
Greenblurr93(QOUTE)yep i recommend the Helm manuel. Honda uses them to publish all thier OEM service manuel. go to www.helminc.com to order one.
Old 04-09-2005, 05:05 PM
hey guys, turns out its the tappets, the garage says they are adjustable so it can be done on the next service, and its not urgent work
Old 04-09-2005, 09:26 PM
If You're Mechanic Charges To High$$$, You Can Always Adjust Them You're Self. I'm Pretty Sure Theres A Write Up On It, If Not It's In A Haynes Manual.
