Old 04-06-2005, 09:45 PM
mclaughlin motors mclaughlin motors is offline
Angry 99 grand am gt abs light no rear brakes
I have no rear brakes at all. good master cycinder. can not get fluid to rear.need ideas
Old 04-07-2005, 05:21 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 99 grand am gt abs light no rear brakes
It sounds like you have a stuck ABS pump that will not allow the fluid to move from the master cylinder to the rear. I would take it to a garage where a technician can use a scan tool to diagnose the problem. ABS is quite complicated so you are better off leaving it to the pros.
Old 04-07-2005, 11:58 AM
Hoags's Avatar
Hoags Hoags is offline
GTP Dad is right, you definitly have a brake fluid issue to the rear wheels. Have you tried setting the parking brake to see if the rear brake assemblies are operating? If they work then you know that you have a hydraulic problem to the rear. That is one for the Pro's, You don't want to mess with the ABS system if you dont know what you are doing. It is too easy to foul things up. ( I'm not questioning your abilities) but like GTPDad says it's a complicated system.
Good luck
Old 04-10-2005, 05:31 AM
Knifeblade Knifeblade is offline
You Betcha, don't even think think of backyarding an ABS system, trust GTP and Hoags on this one!!!!
