Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 04-06-2005, 07:44 PM
monte-man monte-man is offline
keyless programming ? for 96 Monte - Which wire
Can someone provide me with some detailed info on which wire in the truck of the car to ground so I can program my keyless.
Thanks for the help !!
Old 04-06-2005, 08:06 PM
montie0690 montie0690 is offline
Re: keyless programming ? for 96 Monte - Which wire
Are you looking for a wire to ground or just a good spot to ground to?
hit me back or check me out cardomain
Old 04-06-2005, 08:36 PM
I figured it out - monte keyless remote 1996
I found the single black adapter (connector) right by the antenna in the trunk and grounded it to the antenna mounting plate inside the trunk using alligator clips. All 3 locks functioned, then I pressed my door button on my remote to activate the new remote and it works fine and dandy. All 3 buttons work. I had the car on, but not started while I did this.
Old 04-07-2005, 04:02 AM
so what exactly are you asking then? if you are looking for a good ground spot there is one under your carpet just to the inside of your tail light its about a 5/8" bolt. but if it works with the ground you have then you should be fine.
