Old 04-06-2005, 02:59 PM
Psychogamer247 Psychogamer247 is offline
Speed Limiter Questions
I have a 2000 silverado 6000 series v8 does anybody know how to remove the speed limiter or know any quick tricks to boost power?
thanks
Old 04-06-2005, 03:03 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Hypertech programmer.
*Under Construction - New sig to debut*
Old 04-06-2005, 05:58 PM
airtight_python airtight_python is offline
Re: Speed Limiter Questions
Doesn't the Hypertech allow you to match the speed rating of tires? The highest on the programmer at 128? Quick trick to boost power... hmm... I don't know of anything "quick" that would really be worth the power gains noticed.
Old 04-06-2005, 09:43 PM
Re: Re: Speed Limiter Questions
Yea, you can set your speedo by specifying what size tires you have.
Old 04-07-2005, 05:29 PM
thanks
Old 04-08-2005, 02:19 PM
jveik jveik is offline
so the speed limit of a truck like that i heard was 109, if there was no speed limiter, what would the top speed then be?
Old 04-08-2005, 02:38 PM
I have an '02 that's governed at 97. A family member of mine has a 99 Silvy that was governed at 99 mph until he bought the hypertech and moved it to something like 125. The top speed of your truck will depend upon, weight, gearing and motor quite a bit. Someone a while back posted that they reached a speed of around 160 with the 5.3L I believe. I dont remember if it was all motor or not.
Old 04-09-2005, 03:53 PM
yeah i dont think a 5.3 could do even close to 160 without mods. i have a 350 that is in my non-computer controlled truck and that engine maxes out at im guessing roughly 110 on the flat
Old 04-09-2005, 04:10 PM
If my V6 were not governed I'd have to say it would max at around 120. If I remember correctly, at 95 its in 4th gear at just under 3000 rpm. I should add that I've got the 3.42 rear end and auto trans.
Old 04-10-2005, 01:37 PM
oldschooldeathwish oldschooldeathwish is offline
as long as the engise has enough torque it will keep going until it maxes out rpm's
