Old 04-06-2005, 02:35 PM
Old and good Old and good is offline
Send a message via MSN to Old and good
some trouble with my car.....
the ball bearing on my car is failing. does anyone know how much work and what parts i need to fix them?
Old 04-06-2005, 02:51 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: some trouble with my car.....
Just a little vague! There are ball bearings all over the place! Which ones??
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 04-06-2005, 02:56 PM
wups yea the ones on the end of the front axle. they are begining to click when the steering wheel is turned
Old 04-06-2005, 07:26 PM
omaro86 omaro86 is offline
Re: Re: some trouble with my car.....
I think you mean ball joints?
Old 04-06-2005, 07:48 PM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
The CV Joints...? main thing you can do is first... the main reason why they are clicking is most likey because you have a riped cv boot and all the greas is goine and geting dirt up in there... now if the cv joint is shot you will need to replace it but it still might be saveable... you need to disable the axle... clean off the joint with some strong cleaner like "brakes parts cleaner" then after that buy a cv boot kit (it will come with grease) you will need to pack the bearing with grease and the assmble it with the boot full of grease... and you should be good.
Upgrades... To many to list...
Old 04-06-2005, 11:33 PM
uncutnick3kgt uncutnick3kgt is offline
Send a message via AIM to uncutnick3kgt
just go get a new/remanufactured drive axel from a napa or something... there only like 70 - 100 bucks.... replace it now before its rips and ur stuck somewhere and they wont give u the core charge.... trust me happened twice... its not that hard to do on your own just remove the nut on the end of the axel that holds it to the rotor. and then there is a bracket with 2 bolts that is easy to get to...
Old 04-07-2005, 07:35 AM
do you know it the cv joints for the dohc version work for the sohc's?
