Old 04-06-2005, 03:28 PM
dieseldoc dieseldoc is offline
start up squeal
ok i read a thread awhile back on this but can't find it again. someone said you can grease a bearing on the starter or something to get rid of it. it only last like a sce after start up. can anyone be more spacific? also the 6-disc changer doesn't read that there are any songs on the discs, does this mean the changer is shot or is something unpluged? thanks for any help you all can give me.
Old 04-07-2005, 01:40 AM
00blackzx3 00blackzx3 is offline
Re: start up squeal
i hear the sqeaking noise when i first start my car, but it goes away in less than 2 seconds
Old 04-07-2005, 02:47 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: start up squeal
for the disc changer, if your cd's are in and nothing is playing then it most likely means that you put the cd's in the wrong way. they're supposed to be in upside down. try that and see if the music plays.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 04-07-2005, 03:18 AM
Re: Re: start up squeal
Ok, one problem down only one left to go. thanks 00blackzx3. that did the trick. didn't know since this is my first car with a disc changer in it.if anyone knows bout the starter i will be in great shape.
