Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-06-2005, 12:34 PM
awdpower awdpower is offline
Send a message via ICQ to awdpower Send a message via AIM to awdpower Send a message via Yahoo to awdpower
Problem with clutch
My car is leaking clutch fluid and I fill it up right away when it is empty and when im driving around in the city its fine, but when I go out of town like 40 minutes away thats when i start having problems. the clutch stats getting stuck even though it has plenty of clutch fluid.
Old 04-07-2005, 02:59 PM
joemathews's Avatar
joemathews joemathews is offline
Re: Problem with clutch
Try bleeding the clutch, keep checking the fluid levels, etc. You probably have either a leak or air in the lines. My car had a cracked fitting that was leaking fluid, causing my pedal pressure to dive every 15-20 miles.
1996 Eagle Talon
