Go Back   Automotive Forums Car Chat > Toyota > ES300/ES330/Windom
Old 04-06-2005, 01:13 AM
Underground_Killah's Avatar
Underground_Killah Underground_Killah is offline
Registered User
Heavy Duty Oil Detergent?
Hey, i'm new to this forum and need to help a buddy out whom has a 96 es300.
Question is: What heavy duty oil detergent should i use? Engine needs some cleaning out he has some buildup at the top of the motor and I wanted to clean it out as much as possible with liquids
any one here know how i can do that?
Thanks
Old 04-13-2005, 01:38 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Heavy Duty Oil Detergent?
A very experienced mechanic has recommended to me one quart of Dextron ATF instead of oil in the crankcase. He has always run his cars with this mixture in the crankcase and found it works very well at keeping things clean. ATF has a high detergent content.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 05-05-2005, 01:38 AM
cadifan1 cadifan1 is offline
Also to keep your engine clean you can use the oil they use in Diesel engines. Has a high detergent content.
Best used on already clean engines with fresh gaskets or else you'll probably get some oil leakage because it cleans sooo good.
Old 07-15-2005, 07:00 PM
Brian R.'s Avatar
Resident Chemist
If the diesel oil contains too much ZDTP (phosphorous) then you will deactivate the catalytic converter and you will need to buy a new one.
Old 07-15-2005, 07:24 PM
Forgot about cat converters, not widely used in NZ
Old 07-16-2005, 11:54 AM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
Go search Bobistheoilguy.com forums for oil recommendations.
Buy two cans of seafoam.
Break it down like this:
1/3 of the can goes in with fresh oil
The rest of that can is run through the intake twice (1/3 of a can) to clean the heads, the back of the valves,and somewhat of the combustion chamber. Applied through a vacuum line wth the engine running, which is immediately shut off for 10 min. Crank it up and let it run until the smoke screen you put out dies down - then drive it around until it quits smoking. Being sure to hold gears to the revline a few times.
The second can goes in at the gas pump, just before you fill with fresh fuel so it mixes well.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
