Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 04-06-2005, 12:57 AM
Bernando1 Bernando1 is offline
I cannot loosen bolt on Tcase
I need to check the fluid level on my Tcase. I can loosen the drain bold on the Tcase. but I can not get the fill bolt loose on the Transfer case. any suggestions as to how I can loosen the bolt. I also wanted to make sure I have the correct size of socket. I am using a 1-3/16" socet, I found this to be the best fit.
-Thanks
Old 04-06-2005, 03:24 AM
Cam7 Cam7 is offline
I cant remember what size it is, if it has a good fit it should work. As to loosening the plug try a propane torch and use plenty of pennatraiting oil.
Old 04-06-2005, 06:16 AM
ByronP ByronP is offline
For some reason I want to say the bolt is 30mm. But if you have a SAE socket that fits well you should be OK.
93 ZJ w/V8, BB and UC springs, 31" MTZs, ProComp MX6, FM50, DynoMax Cat, OME SD40, Electric fan conversion
Old 04-06-2005, 08:45 AM
JDPascal JDPascal is offline
Re: I cannot loosen bolt on Tcase
just make a longer handle for the ratchet and remember - righty - tighty --- lefty-loosey. but if you already have the drain plug out - you knew that!
JD
