Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 04-01-2002, 11:18 PM
tmak26b tmak26b is offline
Send a message via AIM to tmak26b
Should I get a newer high milage G20 or older low milage G20
Hey whats new guys. I am trying to locate a P10 for my gf. It would be in the neighbourhood of 3-4K. I currently found 2 in the paper. One is a 91 with 85K for 3K, the other is a 95 with 117K for 4K, original owner. Which one should i get assume the condition is the same/ I am going to call them tomorrow and check it out. Thanks
Old 04-02-2002, 03:54 AM
boingo82's Avatar
boingo82 boingo82 is offline
Can't polish a turd.
Get the '95 I would say...the 91 has auto seatbelts, but the miles are almost ideal for a car that age. The 95 will have dual airbags and those may come in handy some day (though hopefully not). However, the G20 is Consumer Reports' number one rated car for reliability (80% above avg.) and you will be well off with either.
See if you can get maintenance records for both and be sure to get a CarFax report for both. Those prices are darned good but the '95 is a better value if you have to resell.
Nissan makes darned solid cars and my Sentra got up to 186k with few problems before it was totaled.
Old 04-02-2002, 08:40 AM
howard_w13's Avatar
howard_w13 howard_w13 is offline
Re: Should I get a newer high milage G20 or older low milage G20
I say get the 95 but do you homework/research before you buy it.
USA-love it or leave it!!!!!
:coolguy: :coolguy:
"Tis been my observation that a man that freely gives eveyone a piece of his mind ususally has very little left to think with."
Any1 swap. newer rear disks for older drums? jnorth Suburban 0 07-25-2008 05:13 PM
can newer trannys fit on older camrys? samm0 Camry/Camry Hybrid/Vista 2 01-23-2008 12:55 PM
Any way to get both high and low beams? jamyers LeSabre 4 03-16-2007 12:35 PM
newer lincoln rims on older lincoln reallybigfuzzy Continental 2 08-29-2004 09:32 PM
tires getting low milage due to hi tread wear scadaman29325 Engineering/ Technical 4 03-09-2004 09:12 AM
