Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 04-05-2005, 10:17 PM
wehswarriorS-10 wehswarriorS-10 is offline
Send a message via ICQ to wehswarriorS-10
electric fan question on 4.7
ok, i have been wanting to put an electric fan on my 2002 4.7, to get rid of some rotational mass and wind drag, and i popped the hood today to see what it would take and bam, theres already a 14 or so inch one there, and it seems to only kick on when the a/c is on....so if i juss took the belt driven fan off would the factory electric fan kick on at a certain temperature or should i go ahead and put an aftermarket one on the front of my radiator...thanks
Dwight
Old 04-06-2005, 05:36 PM
Dakota00's Avatar
Dakota00 Dakota00 is offline
Send a message via MSN to Dakota00
Yes you can remove the clutch fan. I did about 2yrs ago and I had no problems. I gained a bit of power and mpg. The electric fan kicks in if the engine gets a little hot sitting in traffic.
Anthony
Old 04-07-2005, 10:21 AM
jgeib jgeib is offline
Fan questions
Just a thought, the fan on the 4.7 is a six blade fan if I'm not mistaken. Each blade is bolted to the clutch individually. What would it hurt to unbolt every other blade? Run three blades instead of 6. That way the fan would still be balanced and half the drag. Anyone have thoughts on that? I've wondered myself if the double fan was overkill myself. If one was to do a lot of heavy towing, you would probably want to keep it stock but not for a daily driver.
Old 04-07-2005, 02:29 PM
Skyline_BNR34's Avatar
Skyline_BNR34 Skyline_BNR34 is offline
Registered User
Re: electric fan question on 4.7
aw it wobnt matter go ahead and try it and if it overheats put it back one if not your good as gold
