Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-05-2005, 09:18 PM
turbojoe89 turbojoe89 is offline
No Heat - 1997 Bonneville SSEI Supercharged
I have a 1997 Bonneville SSEI 3.8 Supercharged. Car runs great. Not many problems . . . . except I have no heat. Blower blows cold air even when the auto temp control is at 90 degrees.
Any suggestions?
Old 04-06-2005, 09:23 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: No Heat
Heater core needs to be replaced.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 04-06-2005, 03:14 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: Re: No Heat
or the mixing valve that controls the flow of coolant to the core
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 04-06-2005, 04:02 PM
randman1's Avatar
randman1 randman1 is offline
Re: Re: Re: No Heat
My thoughts too. The air mix actuator controls the amount of heated air that has passed through the heater core as it mixes with outside air instead of the amount of coolant that goes through the core itself, but you have the right idea. Does the temp display blink for a minute or so when you start the car or after adjusting the temp from min to max or vice versa?
Old 09-15-2005, 01:28 PM
bilmcc bilmcc is offline
Re: Re: Re: Re: No Heat
Hey.....
I have the no heat issue (and am taking heat from my wife about it) and my external temperature BLINKS about 30 times. What does the flashing mean?
I am not getting any A/C either.... I am hearing smething under the hood click and "turn on" (compressor?) when I press the A/C button on the dash controls. Could be another issue but thought I'd give more info than not enough.
Old 09-15-2005, 05:39 PM
randman1's Avatar
Re: No Heat
Sounds like another air mix actuator. With a little work, you can verify the problem. First remove the glove box liner (black fuzzy part) by removing the 6~7 7mm screws.
Grab a flashlight and look in the left hole in the black steel dash structure. You should see something similar to the second pic. The silver threaded rod attaches to actuator and moves the air mix door lever (yellowish plastic piece). Start with the temp setting on full hot. Press and hold the temp down (cooler) to full cold while observing the movement of the air mix door lever. Then press and hold temp up (warmer) while observing the movement. The assembly should have about a 90* swing and move smoothly without stopping while adjusting from full hot to full cold and back again. If yours does not behave like this, or doesn't move at all, then the actuator is faulty.
Old 09-15-2005, 07:22 PM
Re: Re: No Heat
Thanks for the speedy reply, I saw another one of your posts with the dash all apart and the great pictures as well.
I saw in another post that the actuator may need re-calibrated (by the dealer?). Is this a possibility if it is moving the 90 degrees?
PS: What function does the metal covering the arm serve?
Old 09-15-2005, 08:52 PM
randman1's Avatar
Re: No Heat
The actual failure code description is "air mix motor circuit open, shorted, or needs calibration". This means that the wire could be cut, shorted to ground, disconnected rod, or faulty actuator. It's not 100% certain that your actuator is shot but is the most likely possibility. The nylon gears become flattened and can no longer adjust the arm.
Since the repair can be difficult and time consuming for a DIY'er or expensive if the dealer does the work, it might be beneficial to have the error codes read first. If you have a 93 or older Bonneville, the error codes can be displayed right on the ECC head. 94 and later need to make the trip to the dealer.
If you are referring to the black steel member that you have to look through to see what's going on, that is a part of the dash assembly. There's no cover to protect the moving parts of the actuator or air mix door. My 90 does have a piece metal that covers the works. There's a substantial amount more wires right in that area and I guess the engineers felt protection was necessary.
